Get Url Of Entry From API
Hi Everyone,
I'm currently able to return an entry from the API however, I don't see anyway to get the full url without getting the parent product/nodes to build the url which wouldn't be efficient.
Here's my code so far.
                if (_token == null || !_token.IsExpired()) _token = GetToken(this.ApiConfig.Username, this.ApiConfig.Password);
                using (var client = new HttpClient() { BaseAddress = new Uri(this.ApiConfig.URL) })
                    client.DefaultRequestHeaders.Authorization = new AuthenticationHeaderValue("Bearer", _token.AccessToken);
                    HttpResponseMessage response = client.GetAsync(String.Format($"/episerverapi/commerce/entries/{entryCode}", entryCode)).Result;
                    if (response.StatusCode == HttpStatusCode.OK)
                        using (StreamReader reader = new StreamReader(response.Content.ReadAsStreamAsync().Result))
                            var json = reader.ReadToEnd();
                            ce = JsonConvert.DeserializeObject(json);
I'm using the models right out of the github api sample located here: https://github.com/episerver/ServiceApi-Client/tree/master/EPiServer.ServiceApi.Client/Models/Catalog.
The, API call to '/episerverapi/commerce/entries/{entryCode}' returns this json.
   "Code":"32452",
   "ApplicationId":"e14675f9-a54b-40bd-a9a1-ccf63e5dd6dd",
   "Name":"11.5mm Dia x 20mm FL, Grade 1, Achromatic Lens",
   "StartDate":"2016-07-08T04:00:00Z",
   "EndDate":"2026-07-19T19:48:24.85Z",
   "IsActive":true,
   "MetaClass":"Part Number",
   "Catalog":"EdmundOptics",
   "MetaFields":[
         "Name":"AdditionalDetail",
         "Type":"LongHtmlString",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Value":""
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
         "Name":"ceCertified",
         "Type":"Boolean",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Value":""
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
         "Name":"DisplayName",
         "Type":"ShortString",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Value":"11.5mm Dia x 20mm FL, Grade 1, Achromatic Lens"
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
         "Name":"Epi_IsPublished",
         "Type":"Boolean",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Value":"True"
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
         "Name":"Epi_StartPublish",
         "Type":"DateTime",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Value":"7/8/2016 4:00:00 AM"
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
         "Name":"Epi_StopPublish",
         "Type":"DateTime",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Value":"7/19/2026 7:48:24 PM"
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
         "Name":"groupCode",
         "Type":"LongString",
         "Data":[
               "Language":"de",
               "Value":"OPL  A"
               "Language":"en",
               "Value":"OPL  A"
               "Language":"en-au",
               "Value":"OPL  A"
               "Language":"en-gb",
               "Value":"OPL  A"
               "Language":"en-ie",
               "Value":"OPL  A"
               "Language":"en-sg",
               "Value":"OPL  A"
               "Language":"es-es",
               "Value":"OPL  A"
               "Language":"es-mx",
               "Value":"OPL  A"
               "Language":"fr",
               "Value":"OPL  A"
               "Language":"ja-jp",
               "Value":"OPL  A"
               "Language":"ko-kr",
               "Value":"OPL  A"
               "Language":"zh-cn",
               "Value":"OPL  A"
               "Language":"zh-tw",
               "Value":"OPL  A"
         "Name":"hazmat",
         "Type":"Boolean",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Value":""
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
         "Name":"InternalNotes",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Value":""
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
         "Name":"isAccessory",
         "Type":"Boolean",
         "Data":[
               "Language":"de",
               "Value":"True"
               "Language":"en",
               "Value":"True"
               "Language":"en-au",
               "Value":"True"
               "Language":"en-gb",
               "Value":"True"
               "Language":"en-ie",
               "Value":"True"
               "Language":"en-sg",
               "Value":"True"
               "Language":"es-es",
               "Value":"True"
               "Language":"es-mx",
               "Value":"True"
               "Language":"fr",
               "Value":"True"
               "Language":"ja-jp",
               "Value":"True"
               "Language":"ko-kr",
               "Value":"True"
               "Language":"zh-cn",
               "Value":"True"
               "Language":"zh-tw",
               "Value":"True"
         "Name":"itemClassId",
         "Type":"Integer",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Value":""
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
         "Name":"newItemClassDate",
         "Type":"DateTime",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Value":""
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
         "Name":"oversized",
         "Type":"Boolean",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Value":""
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
         "Name":"partNumber",
         "Data":[
               "Language":"de",
               "Value":"32-452"
               "Language":"en",
               "Value":"32-452"
               "Language":"en-au",
               "Value":"32-452"
               "Language":"en-gb",
               "Value":"32-452"
               "Language":"en-ie",
               "Value":"32-452"
               "Language":"en-sg",
               "Value":"32-452"
               "Language":"es-es",
               "Value":"32-452"
               "Language":"es-mx",
               "Value":"32-452"
               "Language":"fr",
               "Value":"32-452"
               "Language":"ja-jp",
               "Value":"32-452"
               "Language":"ko-kr",
               "Value":"32-452"
               "Language":"zh-cn",
               "Value":"32-452"
               "Language":"zh-tw",
               "Value":"32-452"
         "Name":"partNumberDescription",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
         "Name":"productClass",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Value":""
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
         "Name":"ProductSchema",
         "Type":"Integer",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Value":""
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
         "Name":"rohsStatus",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Value":""
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
         "Name":"Specifications",
         "Data":[
               "Language":"de",
               "Value":""
               "Language":"en",
               "Value":""
               "Language":"en-au",
               "Value":""
               "Language":"en-gb",
               "Value":""
               "Language":"en-ie",
               "Value":""
               "Language":"en-sg",
               "Value":""
               "Language":"es-es",
               "Value":""
               "Language":"es-mx",
               "Value":""
               "Language":"fr",
               "Value":""
               "Language":"ja-jp",
               "Value":""
               "Language":"ko-kr",
               "Value":""
               "Language":"zh-cn",
               "Value":""
               "Language":"zh-tw",
               "Value":""
   "SeoInformation":[
         "Title":"",
         "Uri":"115mm-Dia-x-20mm-FL-Grade-1-Achromatic-Lens-de.aspx",
         "UriSegment":"11.5mm-dia-x-20mm-fl-grade-1-achromatic-lens",
         "Description":"",
         "Keywords":"",
         "LanguageCode":"de"
         "Title":"",
         "Uri":"115mm-Dia-x-20mm-FL-Grade-1-Achromatic-Lens-en-au.aspx",
         "Description":"",
         "Keywords":"",
         "LanguageCode":"en-au"
         "Title":"",
         "Uri":"115mm-Dia-x-20mm-FL-Grade-1-Achromatic-Lens-en-gb.aspx",
         "Description":"",
         "Keywords":"",
         "LanguageCode":"en-gb"
         "Title":"",
         "Uri":"115mm-Dia-x-20mm-FL-Grade-1-Achromatic-Lens-en-ie.aspx",
         "Description":"",
         "Keywords":"",
         "LanguageCode":"en-ie"
         "Title":"",
         "Uri":"115mm-Dia-x-20mm-FL-Grade-1-Achromatic-Lens-en-sg.aspx",
         "Description":"",
         "Keywords":"",
         "LanguageCode":"en-sg"
         "Title":"",
         "Uri":"115mm-Dia-x-20mm-FL-Grade-1-Achromatic-Lens-es-es.aspx",
         "Description":"",
         "Keywords":"",
         "LanguageCode":"es-es"
         "Title":"",
         "Uri":"115mm-Dia-x-20mm-FL-Grade-1-Achromatic-Lens-es-mx.aspx",
         "Description":"",
         "Keywords":"",
         "LanguageCode":"es-mx"
         "Title":"",
         "Uri":"115mm-Dia-x-20mm-FL-Grade-1-Achromatic-Lens-fr.aspx",
         "Description":"",
         "Keywords":"",
         "LanguageCode":"fr"
         "Title":"",
         "Uri":"115mm-Dia-x-20mm-FL-Grade-1-Achromatic-Lens-ja-jp.aspx",
         "Description":"",
         "Keywords":"",
         "LanguageCode":"ja-jp"
         "Title":"",
         "Uri":"115mm-Dia-x-20mm-FL-Grade-1-Achromatic-Lens-ko-kr.aspx",
         "Description":"",
         "Keywords":"",
         "LanguageCode":"ko-kr"
         "Title":"",
         "Uri":"115mm-Dia-x-20mm-FL-Grade-1-Achromatic-Lens-zh-cn.aspx",
         "Description":"",
         "Keywords":"",
         "LanguageCode":"zh-cn"
         "Title":"",
         "Uri":"115mm-Dia-x-20mm-FL-Grade-1-Achromatic-Lens-zh-tw.aspx",
         "Description":"",
         "Keywords":"",
         "LanguageCode":"zh-tw"
         "Title":"",
         "Uri":"32452",
         "Description":"",
         "Keywords":"",
         "LanguageCode":"en"
   "Prices":[
   "EntryType":"Variation",
   "ChildCatalogEntries":[
   "InventoryStatus":"Disabled",
   "WarehouseInventories":[
   "Associations":[
   "Assets":[
   "Nodes":[
         "Title":"Achromatic Lenses",
         "Type":"CatalogNode",
         "Href":"/episerverapi/commerce/nodes/310",
         "Properties":[
               "Name":"Code",
               "Value":"310"
   "Variation":{
      "MinQuantity":0.000000000,
      "MaxQuantity":0.000000000,
      "Weight":0.0,
      "TaxCategory":""
Again, I'm looking to get the full url of the given entry. Any idea how to do this without doing additional calls to the parents to get the permalink of each parent product/node?
Paul
#151953
Aug 10, 2016 21:39
Your post is the longest one, ever :).
Technically you can use Uri (115mm-Dia-x-20mm-FL-Grade-1-Achromatic-Lens-en-gb.aspx) to build SEO Uri (http://yoursite/115mm-Dia-x-20mm-FL-Grade-1-Achromatic-Lens-en-gb.aspx)
If you want to use the hierarchical Uri, then your only option is to extend Entry with a property named HierarchicalUri, then add a controller with an action to return your CustomEntry with UrlResolver.GetUrl(ContentReference) to get the value of HierarchicalUri.
I haven't tried that myself, but that should be doable.
/Q
#151956
Aug 10, 2016 23:46
Hi Quan,
My goal here was to make your longest initial post. Did I achieve my goal?
In seriousness, we do use Hierarchical UIL's. You'd mentioned using UrlResolver.GetUrl(ContentReference) however this won't work in a console application correct? We have a custom home built Faceted Search and we'd like to index this data using our current existing code. In order to do this we'll need to get this data indexed using a console application. UrlResolver.GetUrl(ContentReference) only works in the main website episerver project, not the api correct?
-Paul
#151994
Aug 11, 2016 19:16
I'm not sure about UrlResolver - need to take a look at the code to see if it has dependencies on HttpContext (I think it hasn't, but I can be wrong). - but if you can't use it, simply write your code to get the Hierarchical. It's easy enough: get the IContent from ContentReference, cast it to IRoutable to get the UriSegment, then continue with its parent until you reach the Starting point.
/Q
#151995
Aug 11, 2016 19:44
When you referece to IContent, ContentReference and IRoutable, I believe all of these are native Episerver classes/methods. I'm using the Episerver API in a console application like the documentation below. This doesn't reference any of these classes/methods as, correct me if I'm wrong, I believe these exist only in the native Episerver website projects, not in console applications that use the API.
http://world.episerver.com/documentation/Items/Episerver-Service-API/
Am I going about this wrong? Should I use Nuget to include the Episerver reference in my console application, and run this with Episerver CMS attached to my project? This would allow me to use IContent, ContentReference and IRoutable class methods. I just don't know if this is supported.
-Paul
#151996
Aug 11, 2016 19:50
ServiceAPI is just another Commerce (and therefore, CMS) application. So as long as you add the required references, you can access all those classes and methods. Of course some will require HttpContext to work, but not the content system.
/Q
#151997
Aug 11, 2016 19:55
