I can confirm what you did is correct. "IsIgnoreProcessPayment" is a bad property name (wrong grammar) and it's been obsoleted by "PreventProcessPayment". They have same meaning.
However the old code is supposedly working. We'll see if it was a hidden issue.
Regards,
/Q
I have upgraded from Commerce 8.16.1 to 9.20 and have in that process encountered a problem with a workflow.
I have earlier ignored the payment process using the following code:
This used to work and skipped the payment process.
After the upgrade this does not longer seem to work. After some debugging I found that the following code worked for me:
Originally I followed this blog post:
http://vu3lo.tumblr.com/post/128295808606/episerver-commerce-cartcheckout-workflow-with
Does anyone know how to do this, and is able to confirm what I did is correct?
Is there a better way of ignoring the payment process in the checkout workflow?
/Mads
