Not sure about the extended cart view? What do you mean, in Commerce Manager?
/Q
I'm, again, not sure about "the possibillity to sort all columns" - out of the box you should be able to sort by multiple columns. Do you mean you want to sort by column A, then column B?
No, but in the new view not all columns are clickable
The columns in red are not clickable
Technically you can edit Orders-List.xml to specify which columns are sortable (allowSorting property). However, Created and Modified are not sortable due to nature of the query.
/Q
Hi guys!
And thank you very much for the extended Cart view (9.17.0). It now much more easier to see what is a cart and what is a wishlist. I could not find any way to see that before.
The only thing missing is the possibillity to sort all columns. Is that something that is coming or can I in some way fix that myself?
Thanks!
/Kristoffer
