Language Availability
For some reason I am unable to access language setting in commerce manager for any products/categories. I am on Episerver Commerce 9.11. Any idea why this may happen?
#151420
Jul 20, 2016 22:15
To manage languages of catalog contents, you must edit the language of the catalog itself - all children content (categories, products, skus) will inherit the language of the parent catalog.
/Q
#151423
Jul 21, 2016 7:21
Is there any way to change this? We have a huge international catalog. Maintaining 15 different catalogs is going to be impossible. What's the point of having culture specific properties, but not allow culterspecific availability?
#151436
Jul 21, 2016 15:44
Basically no - it's the way languages work for catalog content - the catalog defines all the languages. You can still define all 15 languages on your catalog, but for each catalog content, set the status for each language separately - if you don't want a product to be available in a language, then make that version unavailable.
This can be handled better with Market concept.
#151437
Jul 21, 2016 15:58
Where do you associate a product with a market? I don't see this in Catalog UI or Commerce Manager.
#151438
Jul 21, 2016 16:44
Commerce Manager
Catalog UI
#151440
Jul 21, 2016 16:55
I don't see the Markets tab on the product or category level. The only place I see this is on the catalog level, which again, if I went that route than I'd have to have 15 different catalogs as all of our products have products that vary by region.
#151442
Jul 21, 2016 17:06
I'm on Episerver Commerce 9.11, if that means anything.
#151443
Jul 21, 2016 17:08
Market is per-entry level - you can surely see it on product level. But not category.
If you want to make an entire category available or not in a market, you'll have to do some works to make its entries available/unavailable in that market. Will require some coding, and of course that feature is not available in the UI.
#151444
Jul 21, 2016 17:16
ok, so you can't make a category not available in a market but you can on the entry level. I'm looking at Catalog ui for an entry. Below is a screenshot, where do I need to go from here to edit the markets this entry is available in?
#151461
Jul 22, 2016 16:58
If you look at my screen shot above, the click on Change close to Markets All (top center of your image)
#151462
Jul 22, 2016 17:00
How could I miss that?! That is exactly what I'm looking for. Thanks!
#151463
Jul 22, 2016 17:08
Just a heads up in case this issue comes up in the future, even though you said this feature isn't supported for categories, I was able to successfully add the markets functionality to my category class. I needed to add the code below as a custom property. It wasn't there before, but it is by default inherited from the product class. After adding this property the markets is now working beautifully on everything. Again thanks for you help in pointing me down this direction.
Here is the code.
        [Display(GroupName = "EPiServerCMS_SettingsPanel", Order = 400)]
        [IgnoreMetaDataPlusSynchronization]
        [UIHint("marketsselector")]
        public virtual ItemCollection<string> MarketFilter { get; set; }
Here is a screenshot of it working on a category.
#151464
Edited, Jul 22, 2016 17:18
