It's pretty clear that you are using Solr35SearchProvider and it's configured to use 127.0.0.1:8983 as Solr server. Make sure that your Solr server is running and accessible via that port.
Hah,
Yeah , sorry, indeed it is clear.
Thank you!
I didn't even see it, probably because solr was eliminated from the project and we use Find now.
Weird that it tries to use it. Anyhow, thanks again.
Hello ,
I run commercemanager on IIS and I cannot create custom Order promotion.
Everything goes well until I try to select reward for the order.
When I select "get gift items" and open link "Please select catalog entries" and try to search catalog entries I stumble on an error:
The commercemanager is running on port 4432. Could someone tell me how can I get this working.
Much appreciated!
No connection could be made because the target machine actively refused it 127.0.0.1:8983
Exception Details: System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 127.0.0.1:8983
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.Stack Trace:
Episerver.CommerceManager v 9.16
