Problem solved. We had a javascript that calculated the height of the breadcrumd and for some reason it got stuck in an eternal loop if you directly edited to products in a row. Really strange but case closed.
/Kristoffer
Our Commerce site is built on the Quicksilver installation and we have a strange problem.
If you edit a node without saving/publishing anything and then right away edit another node the browser hangs and you need to refresh (F5) the browser to get out of the deadlock. It happens everytime. If you save or publish the node you can without a problem edit another node right away after.
Has anyone expericened this problem? Could there something in the controller implementation that should be avoided when editing a node or something like that?
All input are welcome!
Thanks!
/Kristoffer
