Routing - CMS vs Commerce
Thas anyone knows if it pocible to make Episerver to use Commerce URI instead of CMS URI? If the solution has the same URL like CMS page and Commerce node?
#149298
May 27, 2016 17:33
Change url segment of episerver node in edit mode? Seems like a bad idea to have both on the same...
#149303
May 28, 2016 23:48
There is no way to ensure that a router will work before a certain router - it's best practice to make sure that your url is handled by only one router.
You can change your "catalog root starting point" UriSegment to make it unique, more information can be found here: http://vimvq1987.com/2016/03/episerver-commerce-routing-internals-part-2/
/Q
#149327
May 30, 2016 8:57
