Proper way to add users to commerce manager
What is theproper way to add user to Commerce manager so that they can access it.
I have a SQL user and gave this user all roles but i still san´t access commerce manager.
Some step by step guide would be nice
Thanks in advance!
#149279
May 27, 2016 14:41
we have the latest version of commerce 9.16
#149280
May 27, 2016 14:42
What I just did:
- Register an user from front-end site.
- Go to CMS Admin, search for that user, then assign him to Administrators, WebAdmins and WebEditors
Then I can use that user to login to Commerce Manager with full access rights.
Not sure what steps did you take?
Regards,
/Q
#149292
May 27, 2016 17:04
I am in the same project as Pawel and I´m not able to create a working user for EPi Commerce.
I went through the following steps:
1. CMS Admin Mode, Under Access Rights -> Create user
2. Assigned the user to the Administrators, WebAdmins and WebEditors groups
3. Logged out from EPiServer
4. Went to the EPi Commerce login page and tried to login with the new user
 but recieved this message: "Login failed. Please try again"
Do you have any more suggestions?
#149758
Jun 07, 2016 10:26
I just tried the same way and it worked for me. Did you make sure your CMS site and Commerce Manager site share the same membership configuration?
Here's mine:
 <membership defaultProvider="CMSMembershipProvider" userIsOnlineTimeWindow="10" hashAlgorithmType="HMACSHA512">
      <providers>
        <clear />
        <add name="MultiplexingMembershipProvider" type="EPiServer.Security.MultiplexingMembershipProvider, EPiServer.Framework" provider1="SqlServerMembershipProvider" provider2="WindowsMembershipProvider" />
        <add name="WindowsMembershipProvider" type="EPiServer.Security.WindowsMembershipProvider, EPiServer" deletePrefix="BUILTIN\" searchByEmail="true" />
        <add name="SqlServerMembershipProvider" type="System.Web.Security.SqlMembershipProvider, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" connectionStringName="EPiServerDB" requiresQuestionAndAnswer="false" applicationName="CommerceDev" requiresUniqueEmail="true" passwordFormat="Hashed" maxInvalidPasswordAttempts="5" minRequiredPasswordLength="7" minRequiredNonalphanumericCharacters="0" passwordAttemptWindow="10" passwordStrengthRegularExpression="" />
        <!-- ECF Start -->
        <add connectionStringName="EcfSqlConnection" applicationName="ECApplication" enablePasswordRetrieval="false" enablePasswordReset="true" requiresQuestionAndAnswer="false" requiresUniqueEmail="true" passwordFormat="Hashed" passwordStrengthRegularExpression="" minRequiredPasswordLength="4" minRequiredNonalphanumericCharacters="0" name="CMSMembershipProvider" type="Mediachase.Commerce.Customers.Profile.Providers.CustomerSqlMembershipProvider, Mediachase.Commerce" />
        <!-- ECF End -->
      </providers>
    </membership>
#149760
Jun 07, 2016 10:40
along with those settings, double check the connection string also to make sure CMS and CM both are pointing to same db.
Regards
/K
#149762
Edited, Jun 07, 2016 12:39
Thanks for quick response.
The membership configurations were indeed different. I made three different tries to set the same configuration in CMS site and the Commerce Manager site.
1. Copied the membership configuration from CMS Site to Commerce Manager Site
2. Copied the membership configuration from Commerce Manager Site to CMS Site
3. Copied your example to both sites
Unfortunately, none of these worked. I just receive the "Login failed. Please try again. " message. Is there any way to trace what´s going on?
(and I have also double checked the connection strings. Both sites are pointing to the same databases)
#149835
Edited, Jun 08, 2016 15:56
I work on the same project as both Björn and Pawel and have infact been able to get this to work by using the CMSMembershipProvider on both the site and in CM. The problem then is only that all registred users are lost since we move from SqlServerMembershipProvider to the CMSMembershipProvider. I think we can work around that issue though.
I just don't understand why the SqlServerMembershipProvider won't work in CM. We are using a different provider type then what exists in Quan's example (System.Web.Providers.DefaultRoleProvider) but it is working on the site so why would that not work in CM?
As we can get this to work now I'm mostly interested as learning experience.
#150592
Jun 23, 2016 9:42
I am also interested in an answer for this, as we are implementing commerce to an existing Cms site and wan to keep the original cms SqlServerMembershipProvider.
I guess I can do as QuickSilver example package and create my own login.aspx.cs override, but still good to get an official answer for this.
br
Per
#181339
Aug 16, 2017 14:25
I got it to work by search and replace the applicationname to the one cms membership provider is using, E.g. search for ECApplication and you will find all the references.
#181350
Aug 16, 2017 16:09
