Not sure if I understand your question correctly - but you can simply listen to OrderGroupUpdated event. PurchaseOrder is an OrderGroup, so you can just convert it to a PurchaseOrder and do the processing there.
Regards,
/Q
Just modify the code like so
private void Current_OrderGroupUpdated(object sender, OrderGroupEventArgs e)
if (send is PurchaseOrder)
Task.Run(()=> DoSomething(sender as PurchaseOrder, e));
Hello All
I have been doing some reading on events within Episerver. I was looking at http://world.episerver.com/documentation/Items/Developers-Guide/EPiServer-Commerce/8/Orders/order-events/ and was wondering if there is any events within Commerce that I can hook into for when a purchase order is created / modified?
I am trying to sync the purchase order to a third party system if that helps.
Paul
