Can you make sure StructureMap, StructureMap.Web And Newtonsoft.Json are all in bin and in correct versions (or set to correct versions in web.config)?
Regards,
/Q
nope, looks good.
<dependentAssembly xmlns="urn:schemas-microsoft-com:asm.v1">
<assemblyIdentity name="StructureMap" publicKeyToken="e60ad81abae3c223" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-3.1.6.186" newVersion="3.1.6.186" />
</dependentAssembly>
<assemblyIdentity name="StructureMap.Web" publicKeyToken="e60ad81abae3c223" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-1.0.0.0" newVersion="1.0.0.0" />
<assemblyIdentity name="StructureMap.Net4" publicKeyToken="e60ad81abae3c223" culture="neutral" />
<assemblyIdentity name="Newtonsoft.Json" publicKeyToken="30ad4fe6b2a6aeed" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-6.0.8.18111" newVersion="6.0.8.18111" />
I can see that the mediashase dlls are compiled with 9.6.1.
Strange that the assembly redirects is not working on backend. Front end is working.
Any idea?
I just tried myself and it works as expect. However I updated CMS.Core - which will update Framework itself.
I think this can be removed:
<dependentAssembly xmlns="urn:schemas-microsoft-com:asm.v1"> <assemblyIdentity name="Newtonsoft.Json" publicKeyToken="30ad4fe6b2a6aeed" culture="neutral" /> <bindingRedirect oldVersion="0.0.0.0-6.0.8.18111" newVersion="6.0.8.18111" /> </dependentAssembly>
Newtonsoft.Json has weird assembly version which might have caused the problem.
Regards,
/Q
HI!
I upgraded front end site from cms.core 9.6.1 to 9.7 and Commerce 9.8.1 to 9.9.
But the back end dll Mediachase.BusinessFoundation.Data and other dlls seems to be asking for Episerver.Framework version 9.6.1, is it not compatible?
Still problems with CM being compatible with all CMS dll versions?
I do have assembly bindings set to:
