Copy page in the tree structure doesn't work
When the page is copied (even in the same lavel), the next error appares
Error
POST http://localhost:60672/EPiServer/cms/Stores/contentstructure/25145 400 (Bad Request)xhr @ dojo.js:15dojo.xhr @ dojo.js:15_88c._sendRequest @ widgets.js:2(anonymous function) @ widgets.js:2(anonymous function) @ dojo.js:15_2f2 @ dojo.js:15then._2ff.then @ dojo.js:15_88c.xhr @ widgets.js:2xhr @ widgets.js:2_867._xhr @ widgets.js:2(anonymous function) @ widgets.js:2(anonymous function) @ dojo.js:15when @ dojo.js:15_867.xhr @ widgets.js:2_81f._send @ widgets.js:2_81f.copy @ widgets.js:2_3db.pasteItem @ widgets.js:2_264.around.advice @ dojo.js:15(anonymous function) @ dojo.js:15(anonymous function) @ widgets.js:2when @ dojo.js:15(anonymous function) @ widgets.js:2_25a.advice @ dojo.js:15_25f.(anonymous function)._264 @ dojo.js:15(anonymous function) @ widgets.js:2(anonymous function) @ dojo.js:15_2f2 @ dojo.js:15then._2ff.then @ dojo.js:15when @ dojo.js:15(anonymous function) @ widgets.js:2_172.map @ dojo.js:15_3db.copy @ widgets.js:2_10f6._execute @ widgets.js:2_11aa.execute @ widgets.js:2_11da.onClick @ widgets.js:2_5c6.onItemClick @ widgets.js:2(anonymous function) @ widgets.js:2(anonymous function) @ dojo.js:15(anonymous function) @ widgets.js:2
dojo.js:15 _317 {message: "Unable to load /EPiServer/cms/Stores/contentstructure/25145 status: 400", response: Object, status: 400, responseText: " ↵
↵ ↵ ↵" , xhr: XMLHttpRequest}>
Error1
error 2
Could you please check the error?
#144013
Feb 04, 2016 13:39
The version EpiServer Commerce version
 <package id="EPiServer.CMS" version="8.11.0" targetFramework="net45" />
 <package id="EPiServer.CMS.Core" version="8.11.0" targetFramework="net45" />
 <package id="EPiServer.CMS.UI" version="8.6.1" targetFramework="net45" />
 <package id="EPiServer.CMS.UI.Core" version="8.6.1" targetFramework="net45" />
 <package id="EPiServer.Commerce" version="8.16.1" targetFramework="net45" />
 <package id="EPiServer.Commerce.Core" version="8.16.1" targetFramework="net45" />
 <package id="EPiServer.Commerce.UI" version="8.16.1" targetFramework="net45" />
 <package id="EPiServer.Commerce.UI.ManagerIntegration" version="8.16.1" targetFramework="net45" />
 <package id="EPiServer.Framework" version="8.11.0" targetFramework="net45" />
 <package id="EPiServer.Labs.LanguageManager" version="1.4.1.8000" targetFramework="net45" />
 <package id="EPiServer.Logging.Log4Net" version="1.0.0" targetFramework="net45" />
 <package id="EPiServer.Packaging" version="3.2.2" targetFramework="net45" />
 <package id="EPiServer.Packaging.UI" version="3.2.2" targetFramework="net45" />
 <package id="EPiServer.Search" version="7.7.1" targetFramework="net45" />
The errors
http://screencast.com/t/mjYu6SyLXpaf
http://screencast.com/t/sswgRgVrWws
I tried to subscribe to the CreatingContent event. The ContentEventArgs e   e.Content  is null.
#144014
Edited, Feb 04, 2016 13:41
Can you try to open the failed request and see what is the wrong with that message. As I see it's an HTTP 400 error, what's the error message?
/Q
#144051
Feb 04, 2016 17:15
Thank you for reply.
The error is:
http://screencast.com/t/5SS2E41vdQyu
http://screencast.com/t/OIKJH6iEVfkQ
http://screencast.com/t/EQ7tRRHg
#144085
Feb 05, 2016 11:44
Check that the current user has access rights to all pages below that page including page files and included blocks. Seems to be an access problem
#144090
Feb 05, 2016 15:06
The user is in the Administrators group and he has full access for each node.
#144091
Feb 05, 2016 15:09
Check file access rights to blobs and that IIS_USERS has write access to all blobs? Does file upload work?
#144100
Feb 05, 2016 17:22
Thank you for help! We will check the access rights to the folder.
#144117
Feb 08, 2016 7:52
Yes, it solved the issue. Thank you!
#144136
Feb 08, 2016 14:12
Nice! Been there done that :)
#144139
Feb 08, 2016 14:30
