I need to check it for sure, but if these conditions are met:
- Those two promotions are not excluded by each other or by other promotions
- The conditions for the second promotion (lower priority) are still satisfied after the first promotion applied. For example the first promotion discounts the cart 50$, making the cart subtotal 480$, while the second promotion requires the cart subtotal to be at least 500$, then it's no longer satisfied.
Then it should be able to apply both promotions.
Regards,
/Q
Hi Quan,
Thanks a lot for giving detail explanation.
It's working as expected now.
Regards
Venkata Phani Kumar R
Hi All ,
Is it possible to apply two order level promotional coupon codes on a cart ?
eg: I have two order level promotional coupons of $30 and $ 50 if I apply both, would I get $80 discount on my Order sub total ?
Episerver verion 9.0
Legacy promotion Engine.
Regards
Venkata Phani kumar R
