In situations like this - when you try to mimic a UI behavior - it helps to fire up the ole reflector =) In your case, I'd take a look in Mediachase.ConsoleManager.dll, starting with MetaFieldEditControl.SaveButton_Click and taking it from there. Good luck, and let us know your findings!
Nevermind.
When I use MetaEnum.AddItem(metaFieldType, value, orderId) instead of adding the items to the EnumItems it works.
Hello,
As part of a scheduled job I want to create a new multi-value MetaField of type Dictionary items and to create the related dictionary items. The issue is the MetaEnumItems are not being created in the mcmd_MetaEnum and mcmd_SelectedEnumValue tables.
I am missing something because they are getting persisted somewhere but I am not sure where as I can retrieve them even after a recycle of IIS.
This is what I am using to create my enum and items:
I appreciate any help!
Note: I believe the field is being created correctly as if I manually add entries in CommerceManager then I can use them without issue. I believe the issue is in how I am creating the enum entries.
