Read-only catalog
In a scenario where the entire catalog is owned by a third-party system, e.g. a PIM, it would be nice if we could make the catalog read-only. Would it be possible to disable catalog editing alltogether or restrict it to certain fields?
#122465
Jun 03, 2015 8:50
I don't think it's possible in CM, but for Catalog UI you can create your own content provider, inherit from CatalogContentProvider and simply does nothing in Save().
To make it truely "Read-only" then you might want to override the LinksRepository as well.
Another approach is to create an implementaion of CatalogEventListenerBase and prevent any modification by throwing exceptions.
Regards.
/Q
#122469
Jun 03, 2015 10:52
Hi Quan
Would the following be possible:
  • Hook into the LoadedContent event on products/variants
  • Get the ACL from IContentSecurable.GetContentSecurityDescriptor()
  • Remove all but Read access rights from the ACL for the product
I've put a POC together for this on content in the past and was wondering if this would work on Catalog entries too?
David
#122492
Jun 03, 2015 12:59
Unfortunately Commerce implemetation of ACL does not support that thing right now - so I don't think that'll be possible.
Regards.
/Q
#122495
Jun 03, 2015 13:18
And to complete my question above, you can also override the ProviderCapabilities property to remove ContentProviderCapabilities.Create/Edit/Delete/Move/Copy enum, then in Catalog UI, options to edit content (move/copy/save...) will be disabled.
/Q
#122588
Jun 05, 2015 15:31
Just an idea :)
var contenEventHandler = EPiServer.ServiceLocation.ServiceLocator.Current.GetInstance<EPiServer.Core.IContentEvents>();
                contenEventHandler.SavingContent+=contenEventHandler_SavingContent;
void contenEventHandler_SavingContent(object sender, ContentEventArgs e)
            //Is it Commerce?
            e.RequiredAccess = AccessLevel.Administer;
            e.CancelAction = true;
Regards
/K
#122653
Jun 09, 2015 11:38
Is Episerver Commerce (Commerce UI, not Commerce Manager) going to have an implementation of ACL similar to the CMS one anytime soon? Meaning, an administrator would be able to set view/edit/create/updat/delete access rights on catalogs, nodes, products, etc?
#172237
Nov 28, 2016 14:47
It's in our backlog, but it would not happen anytime soon (I'm talking about 3-6 months period)
/Q
#172238
Nov 28, 2016 14:50
Thank you Quan for your quick response :)
#172239
Nov 28, 2016 14:53
Any news on this? Has ACL been implemented for Commerce?
#217135
Feb 18, 2020 9:16
It has been implemented in Commerce 11.6.0 https://world.episerver.com/documentation/Release-Notes/ReleaseNote/?releaseNoteId=COM-49, limited to catalog and categories (entries inherit the setting from it true perent
#217136
Feb 18, 2020 9:19
- Feb 18, 2020 9:23
Thanks!
