Exception when using Transactions and Azure
I'm seeing this exception intermittently when using Transactions and Azure:
The transaction manager has disabled its support for remote/network transactions. (Exception from HRESULT: 0x8004D024)
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in thecode.
Exception Details: System.Runtime.InteropServices.COMException: The transaction manager has disabled its support for remote/network transactions. (Exception from HRESULT: 0x8004D024)
[COMException (0x8004d024): The transaction manager has disabled its support for remote/network transactions. (Exception from HRESULT: 0x8004D024)]
System.Transactions.Oletx.IDtcProxyShimFactory.ReceiveTransaction(UInt32 propgationTokenSize, Byte[] propgationToken, IntPtr managedIdentifier, Guid& transactionIdentifier, OletxTransactionIsolationLevel& isolationLevel, ITransactionShim& transactionShim) +0
System.Transactions.TransactionInterop.GetOletxTransactionFromTransmitterPropigationToken(Byte[] propagationToken) +315
Has enyone else experienced the same?
/Mark
#122582
Jun 05, 2015 14:30
What's the code you are using? I suspect you might have conflicted scopes of transaction.
/Q
#122584
Jun 05, 2015 15:00
Hi Quan Mai,
Here's the piece of code:
using (var transactionScope = new TransactionScope())
  try
    OrderGroupWorkflowManager.RunWorkflow(cart, OrderGroupWorkflowManager.CartCheckOutWorkflowName);
  catch (Exception ex)
    if (ex is PaymentException)
      throw;
    if (ex.InnerException is PaymentException)
      throw;
// store customer information on cart
cart.CustomerName = CurrentContact.FullName;
cart.CustomerId = CurrentContact.PrimaryKeyId.Value;
cart.OrderForms[0].Payments[0].Status = response.AuthResult;
var purchaseOrder = cart.SaveAsPurchaseOrder();
// store latest order information on contact
CurrentContact.LastOrder = purchaseOrder.Created;
CurrentContact.SaveChanges();
purchaseOrder.Status = response.AuthResult;
AddNoteToPurchaseOrder("New order placed by {0} in {1} site", purchaseOrder,
CurrentContact != null ? CurrentContact.FullName : string.Empty, SiteDefinition.Current.Name);
purchaseOrder.AcceptChanges();
PurchaseOrderManager.UpdatePromotionUsage(cart, purchaseOrder);
//CmoGadgetController.IncreaseOrder(this.CartHelper.LineItems);
cart.Delete();
cart.AcceptChanges();
transactionScope.Complete();
#122585
Jun 05, 2015 15:03
Does this code work on local environment (Non-Azure)? And it's unlikely, but it should be Mediachase.Data.Provider.TransactionScope, not .NET TransactionScope.
/Q
#122586
Jun 05, 2015 15:10
