The published date for catalog contents (node, entry, etc.) is supposed to be the StartDate (as you can see in Commerce Manager).
It's a bit confusing but it's the way it works now.
Regards.
/Q
ok thanks!
is there a way to see this date when editing properties or do we have to go to Options?
because we see only these dates:
Regarding the field StartDate, i can´t find it anywhere..
I can find startpublish and stoppublish.. the problem is startpublish is not getting updated when we acutally publish an article..
sorry my bad i can find StartDate but it does not getting updated when publishing.. is keeps the created date all the time
The published date will not be updated when you publish, but you can still change it on Settings tab.
Regards.
/Q
I think you can use IContentVersionRepository to get the version list of a specific catalog content and see when the published version was published.
Regards.
/Q
Im having a variant that is nbot published and only created..
Problem is i have a published date in settings..
Also when i finally publish the variant the publisched date is not updated...
could someone explain how is meant to work?
Thanks!
