Managing Workflows
Hey,
How do you guys manage customizing the workflows?  If you have customized workflows in your project, and Episerver changes the workflows how do you ensure that you implement their changes?  One way I guess would be to redownload the zip file from episerver each time and do a diff and implement the changes but this doesn't seem the best way to me.
#119913
Apr 07, 2015 13:14
We have just experienced this exact issue.  We have had to redownload and reimplement unfortunately, as it doesn't seem there is any other solution.
#119921
Apr 07, 2015 15:58
One solution I can suggest is to add reference to Mediachase.Commerce.Workflow.dll, and then override the activity you want to have custom implementation. Then you define your own xoml file and register it in ecf.workflow.config. In this way when you update Mediachase.Commerce.Workflow.dll you won't need to update the code manually.
Regards.
/Q
#119922
Apr 07, 2015 16:22
Hi, we experience issues with the current setup too currently we are maintaining a git repository of the releases from which we branch . This allows for a 3-way merge when we get new releases and makes this process a little easier.
The syncing of workflow code and NuGet releases is not ideal. New code is released onto http://world.episerver.com/download/Items/EPiServer-Commerce/episerver-commerce-8-tools-and-code-samples/ against a major revision i.e. 7.5 or 8 with a release date rather than a update revision i.e. EPiServer - update 58 (there is also no archive that I am aware of). As such unless we note the release dates we dont know that theres been a modification. When a new update is released we are having to take an educated guess if its safe to update based on the listed changes of that update, forum posts and the date of the latest workflow source release.
I understand that modifiying such code whilst expecting updates is going to be somewhat painfull but it would be easier if an archive of the released workflow code versioned by the major release and update increments was available and if every update had a paired code release removing any ambiguity.
Creating a public repository from which releases were tagged and clients could branch\make use of externals to include the source and leverage 3 way merge when integrating your changes into what are likely heavily modified workflows\activities would be even better.
Andrew
#120408
Apr 16, 2015 11:22
Currently the latest source release appears to be from January and we have integrated this against update 57 (we required another fix so had no choice even though it may not match). This made assumptions that we are not missing breaking changes which would have been in the compiled versions compared to the released source and that if it was workable we could catch up with the fixes with a subsequent release. If we assume this was the correct version, since then update 58 has been released seemingly without a new release of the source. Update 58 specifically comments about changes to the workflow to accomodate a promotions change so we know we will be missing changes if we upgrade but do not know the impact.
I hope there is a release page I am unaware of but at the moment we are unable to upgrade and have an expectation of functioning code aftwards unless we first decompile the latest released dll's and diff them to see whats actually changed.
Andrew
#120412
Apr 16, 2015 13:11
Thanks for the feedback.  I was thinking Andrew, that we could just put it in a github repo but hopefully the replacement for workflows will mean this is no longer an issue.  For now I have added everything to our repo and will do a compare each time.  I like Quan's idea but not sure we are ready for that route yet.
#120440
Apr 16, 2015 23:18
