Integrating episerver cms with commerce
Hello, i have a question or searching for advice regarding an integration of an already existing and live version of a cms solution with a commerce solution
My case:
I have a CMS website deployed and working. My client wants to add a commerce solution to it. Do i need to create a whole new VS solution with commerce in which i import the files from the cms solution or is there a way to connect the cms solution to a commerce solution?
thanks in advance
#118906
Mar 17, 2015 10:15
It's simple as that:
In short, you just need to install EPiServer.Commerce on your front-end (currently CMS site), add a new empty project to your solution and install EPiServer.COmmerceManager on it, and you should be good to go.
The only drawback is you need to be 7.5+ to make it works :)
Regards.
/Q
#118911
Mar 17, 2015 11:20
version please :)
#118982
Mar 18, 2015 11:56
@ K khan 7.13
#119162
Mar 23, 2015 13:22
