Cart workflows in Azure
Is it correct that the cart workflows (CartValidateWorkflow, etc) are not supported in Azure? What are the alternatives and are there any samples, so I don't have to copy paste all the logic from the workflows?
#118627
Mar 11, 2015 11:30
No, our workflows are supported on Azure - all of them run without problem.
Regards.
/Q
#118628
Mar 11, 2015 11:34
Ok that's good news, thanks for the quick response!
#118629
Mar 11, 2015 11:46
Are they still supported on Azure? I'm confused by the following paragraph in the article about commerce 9 http://world.episerver.com/blogs/Magnus-Strale/2015/4/there-will-be-a-commerce-9/
"Remove dependency on WWF (Windows Workflow Foundation), where WWF 3 that we are using is now obsoleted and (officially) not supported on Azure, We will provide a compatibility layer that allows customized workflow activities to be re-used with VERY MINOR modifications. NOTE! It will NOT be 100% source code compatible so dev resources are required for an upgrade. The positive aspect is that a number of partners have asked for / begged us to remove WWF for quite some time, so I expect this will not be such a negative thing after all."
#121085
May 01, 2015 3:58
The statement is in Commerce 9 we will remove dependencies on WF 3.5. The Azure support will remain the same in current version.
Scenarios are:
- If you upgrade to Commerce 9, there will be no dependencies on WF 3.5. You'll need to update your code but your site will be future-proof.
- If you keep your current version, it will continue to run on Azure until the day Azure no longer support WF libraries.
We would recommend to upgrade to Commerce 9 when it's available ASAP, not only to remove WF dependencies, but other bug fixes, new features and performance improvements.
Regards.
/Q
#121087
May 01, 2015 10:37
Ok thanks again for the quick response. When is the expected commerce 9 release date? And did MS said anything about when they would stop supporting WF libraries?
#121097
May 01, 2015 19:00
We don't have the fixed date yet, but the timeframe is about June-July.
And MS did not say anything about when they would stop supporting WF libraries, to my knowledge.
Regards.
/Q
#121120
May 02, 2015 9:15
