Workflow project not compiling after upgrade
Updated Commerce from 8.2.1.326 to 8.7.1.466 (and CMS 7.15 to 7.19.2)
After that my custom workflow project did not compile in VS2013. My workflows are deriving from Mediachase.Commerce.Workflow.Activities.CalculateTaxActivity (one example)
Error in VS2013: "Compilation failed. Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information."
I’ve noticed that the dll “Mediachase.Commerce.Workflow.Activities.dll” is moved in to “Mediachase.Commerce.Workflow.dll” (not mentioned in release notes – why Episerver? ).
Therefor I changed the assembly namespace in myworkflow.xoml
xmlns:ns0="clr-namespace:Mediachase.Commerce.Workflow.Activities;Assembly=Mediachase.Commerce.Workflow, Version=8.7.1.466, Culture=neutral, PublicKeyToken=null"
In VS I also get the following when I try to open the workflow designer:
“The designer could not be shown for this file because none of the classes within it can be designed. The designer inspected the following classes in the file: MyValidateLineItemsActivity. The base class MyValidateLineItemsActivity could not be loaded. Ensure the assembly has been referenced and that all projects have been built.”
The MyValidateLineItemsActivity assembly is in the project.
The Mediachase DLLs are referenced to the latest version.
What am I missing out? Thanks for any help.
#116858
Feb 06, 2015 11:21
When you use namespace within an assembly, you don't have to specify the Assembly part, so you just want to remove that part. Your xoml should be
xmlns:ns0="clr-namespace:Mediachase.Commerce.Workflow.Activities"
But I'm quite sure we noticed about the merge. In the release notes here http://world.episerver.com/releases/episerver---update-51/ we pointed to
http://world.episerver.com/download/Items/EPiServer-Commerce/episerver-commerce-8-tools-and-code-samples/
"This code package includes the source code for the default workflows in EPiServer Commerce, combining both workflows and activities into one package. The workflows can be customized to suite specific implementation needs."
:)  But that might be a little mild.
Regards,
/Q
#116868
Feb 06, 2015 13:24
Thanks but changing namespace did not change anything. Looked at the example and i didn´t see any that clarify my problem.
#116900
Feb 06, 2015 15:32
And did you remove the reference to Mediachase.Commerce.Workflow.Activities.dll and Mediachase.Commerce.Workflow.dll itself? The steps were to install EpiServer.Commerce.Core to the source code project but old references must be removed.
/Q
#116904
Feb 06, 2015 15:44
Yes, its all gone and changed. Still i believe it is a reference issue as the message tells me.
#116905
Feb 06, 2015 15:57
I also tried to update last night and am in the situation receiving the same error with my custom workflows project. I look forward to more information or a solution to this. Thanks.
#116946
Feb 07, 2015 17:44
Would you mind to send us your custom project? We will try to make things right. My mail is quma [at] episerver.com
Thanks.
/Q
#116947
Feb 08, 2015 3:24
I wrote a blogspot which might help future visitors: http://world.episerver.com/blogs/Quan-Mai/Dates/2015/2/building-your-customer-commerce-workflow-project/
Regards,
/Q
#116954
Edited, Feb 09, 2015 6:03
Have you tried to clean you solution, hit the refresh button to refresh your workflow project, and rebuild the solution?
#117021
Feb 10, 2015 9:17
I finaly got my workflow-project working in CMS 7.19.2. What i did was to download 7.19.1 separatly, and referenced my workflow project to these DLLs. Anyhow this is not desirable approach. I wonder what will happen on next update.
#117344
Feb 18, 2015 12:57
Oh, i didn't try it enough. Now i get this error on "OrderGroupWorkflowManager.RunWorkflow(cart, OrderGroupWorkflowManager.CartPrepareWorkflowName);"
 System.MissingMethodException: Constructor on type 'Holmen.Commerce.CustomProviders.ShippingUps.AdaptorGateway' not found.
   at System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark)
   at System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
   at System.Activator.CreateInstance(Type type, Object[] args)
   at Mediachase.Commerce.Workflow.Activities.ProcessShipmentsActivity.ProcessShipments()
   at Mediachase.Commerce.Workflow.Activities.ProcessShipmentsActivity.Execute(ActivityExecutionContext executionContext)
   at System.Workflow.ComponentModel.ActivityExecutor`1.Execute(T activity, ActivityExecutionContext executionContext)
   at System.Workflow.ComponentModel.ActivityExecutorOperation.Run(IWorkflowCoreRuntime workflowCoreRuntime)
   at System.Workflow.Runtime.Scheduler.Run()
   at Mediachase.Commerce.Orders.Managers.OrderGroupWorkflowManager.RunWorkflow(OrderGroup orderGroup, String name, Boolean async, Boolean throwException, Dictionary`2 param)
   at Mediachase.Commerce.Orders.Managers.OrderGroupWorkflowManager.RunWorkflow(OrderGroup orderGroup, String name)
   at Holmen.Externweb.Web.Templates.Public.Pages.Commerce.Checkout.CheckoutPaymentOptions.onEnter() in c:\workspace\Holmen\Holmen.Externweb.Web\Templates\Public\Pages\Commerce\Checkout\CheckoutPaymentOptions.aspx.cs:line 60
   at Holmen.Externweb.Web.Templates.Public.Pages.Commerce.Checkout.CheckoutStepBase`1.InitGeneral() in c:\workspace\Holmen\Holmen.Externweb.Web\Templates\Public\Pages\Commerce\Checkout\CheckoutStepBase.cs:line 39
   at Holmen.Externweb.Web.Templates.Public.Pages.Commerce.Checkout.CheckoutPaymentOptions.Page_Load(Object sender, EventArgs e) in c:\workspace\Holmen\Holmen.Externweb.Web\Templates\Public\Pages\Commerce\Checkout\CheckoutPaymentOptions.aspx.cs:line 36
   at System.Web.UI.Control.LoadRecursive()
   at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
   at System.Web.UI.Page.HandleError(Exception e)
   at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
   at System.Web.UI.Page.ProcessRequest()
   at System.Web.UI.Page.ProcessRequest(HttpContext context)
   at ASP.templates_public_pages_commerce_checkout_checkoutpaymentoptions_aspx.ProcessRequest(HttpContext context) in c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\21f9142c\f8f72cc1\App_Web_checkoutpaymentoptions.aspx.c1d148f9.twvxtly2.0.cs:line 0
What does it meen? please help.
Holmen.Commerce.CustomProviders.dll is in the bin-folder
#119673
Edited, Apr 01, 2015 13:47
"Constructor on type 'Holmen.Commerce.CustomProviders.ShippingUps.AdaptorGateway' not found." indicates that the class AdaptorGateway was missing a public, parameterless constructor. You'll need to add it to make it works.
Regards.
/Q
#119679
Apr 01, 2015 14:43
Hi Q,
Thats what i thought too. But we have never had one. And it doesnt make any change.
 public class AdaptorGateway : IShippingGateway
        public AdaptorGateway()
Ive also tried to compile the project with 7.19.1 as this answers anticipate http://stackoverflow.com/.../activator-createinstance-cant-find-the-constructor-missingmethodexception
Any other idea?
#119682
Apr 01, 2015 15:00
I just took another look at the code and it looks like you'll need to add a constructor with IMarket parameter as well
/Q
#119688
Apr 01, 2015 15:12
The Great Quan Mai, you did it again! Greatly appreciated. I was just about to look in ProcessShipment(), and there i see IMarket, yes!
#119690
Edited, Apr 01, 2015 15:32
