I would suggest you to run your query with this "tool": http://world.episerver.com/blogs/Quan-Mai/Dates/2014/10/Order-searchmade-easy/
I think the SqlMetaWhereClause is not correct? Shouldn't it be "META.DocNumber IS NOT NULL"?
Regards,
/Q
I've just checked the DB and there are some rows in [OrderFormEx] which has value in field "DocNumber" for sure.
What is wrong?
Hi Quan,
Thanks for your fast responces.
I also thought of that but still no records. I will try the tool, and come back to you. thanks
Hi again,
I am really confused :)
I could make my query work, but with joining and putting everything in where clause. but I don't like it this way. Do you have any advice?
var searchOptions = new OrderSearchOptions
CacheResults = false,
StartingRecord = 0,
RecordsToRetrieve = 10,
Namespace = "Mediachase.Commerce.Orders"
OrderSearchParameters parameters = new OrderSearchParameters();
searchOptions.Classes.Add("PurchaseOrder");
parameters.SqlWhereClause =string.Format( "OrderGroupId IN (SELECT OrderForm.OrderGroupId FROM OrderForm LEFT OUTER JOIN OrderFormEx ON OrderForm.OrderFormId = OrderFormEx.ObjectId WHERE (OrderFormEx.DocNumber = '{0}' ))", DocNumber);
var purchaseOrderCollection = OrderContext.Current.FindPurchaseOrders(parameters, searchOptions);
I need to find orders which has a special metaField and I am using EPIServer 8.11.0.0. I tried Order Search described in this article. but it returns no row.
To make it simpler, I tried to find orders that the field is not null but still I there was no success. I know that I used the correct fields and classes since it returns data when I ask for "field is null".
Any Guidance?
//Returns purchaseOrderCollection[0]
