GetTotals() in IOrderGroup - Version 9.4
I need to override the method GetTotal in the new IOrderGroup, to my own calculation.
Is there a way?
#142548
Dec 14, 2015 15:51
One possible way is to create your class (CustomPurchaseOrder for example) inherits from PurchaseOrder and override it there.
Make sure to use the new class when you use IOrderRepository
/Q
#142549
Dec 14, 2015 16:07
ok
Why PurchaseOrder?Does PurchaseOrder have it? GetTotals()?
I need to use it like:
((IOrderGroup)Cart).GetTotals() and it will return a class "OrderGroupTotals" with all values.
The problem I have is that TaxTotal is "0"
Juan
#142550
Dec 14, 2015 16:17
GetTotals is a method of IOrderGroup, so you can override it with your custom PurchaseOrder.
But if your problem is TaxTotal then the solution can be different - implement your own ITaxCalculator and register it as the default implementation in your initialization module.
Regards,
#142551
Dec 14, 2015 16:24
Is there any sample code of it?
I found "DefaultTaxCalculator"...
#142552
Edited, Dec 14, 2015 16:27
<p>http://world.episerver.com/documentation/Class-library/?documentId=commerce/9/277D3EB8</p> <p>Here's an example. You just need to implement two methods.</p> <p>/Q</p>
#142554
Dec 14, 2015 16:29
Perfekt
Thanks Quan!
#142555
Dec 14, 2015 16:31
<p>Just one more question Quan.</p> <p></p> <p>I did my new class that override the taxcalculation, now how do I register it in my initialization module?</p>
#142557
Dec 14, 2015 16:45
Some thing like this, your initialization module needs to implement IConfigurableModule
public void ConfigureContainer(ServiceConfigurationContext context)
    context.Container.Configure(ce => ce.For<ITaxCalculator>().Add<YourTaxCalculator>());
#142558
Dec 14, 2015 16:49
Thanks!
#142559
Dec 14, 2015 17:01
