Add notes to contact Dynamically
We are using Episerver commers 8.16.1 and I am looking for a way to add notes to the customer dynamicly. Any Help would be appreciated.
#142809
Dec 29, 2015 20:55
By dynamically you mean programmatically? By code?
/Q
#142816
Dec 30, 2015 17:31
var note = new EntityObject("ContactNote");
note["ContactId"] = new PrimaryKeyId(new Guid("{id-of-your-customer-contact}"));
note["NoteTitle"] = "...";
note["NoteContent"] = "...";
var pk = BusinessManager.Create(note);
Other properties you may be interested in:
- CreatorId
- ModifierId
- NoteType
#142825
Dec 30, 2015 23:36
Yes by code. I need to add a note to the customer object much like a note can be added to the order object. So that the note will be viewable in the commers manger when you are looking at contat->notes.
#142828
Dec 31, 2015 18:14
As you want to see this field in Commerce Manager, therfore you can create a metafield (Notes) for Contact Object, Update that field in your code, pseudo code will be something like
customContact["NewMetafIeld"] = "customer notes"
customContact.saveChanges()
Regards
/K
#142834
Jan 03, 2016 18:01
There are 2 types of built-in notes for contact object: ordinary notes and order notes. code above adds new ordinary note to the contact and it's available for admins via Commerce Manager UI.
#142835
Jan 03, 2016 20:45
