Commerce Manager
Hello... Please, help me. I have some problems. I want to add a reference to the 'COMMERCE' manager in admin panel. I added to the solution of the project, which has COMMERCE manager. It works and site works ( separately ). But the administration panel, in the category of Commerce, I see only "Catalogs" and "Settings".
I don't know what to do.
Thank you in advance.
P.S. (Sorry for my English)
#141327
Nov 12, 2015 10:33
The Commerce manager menu integration is in EPiServer.Commerce.Shell.ManagerIntegration library. It should be somewhere in bin directory. Do you have it?
I added Commerce Manager to the CMS through Nuget Package and had no problems. Did you do this same way?
#141334
Nov 12, 2015 12:42
Make sure to install this http://nuget.episerver.com/en/OtherPages/Package/?packageId=EPiServer.Commerce.UI.ManagerIntegration
to your project. It'll add required files to show the Commerce Manager menu
Regards,
/Q
#141346
Nov 12, 2015 16:14
What version you are on?
#141394
Nov 13, 2015 17:47
Step by step
1. I created project (add to solution with my shop)
Create web ptroject
Choosing template (Empty)
Choosing empty template
I installed EPiServer.CommerceManager (Version 9.2.1) and Episerver.Core (Version 9.3.1)
Install Episerver.CommerceManager
In Config file, system automaticly choosing my database|(shop data base)
<add name="EPiServerDB" connectionString="Data Source=(LocalDb)\MSSQLLocalDB;AttachDbFilename=C:\Users\Alex\Documents\Visual Studio 2015\TEST\PhoneShop\PhoneShop\App_Data\EPiServerDB_245f2d79.mdf;Initial Catalog=EPiServerDB_245f2d79;Connection Timeout=60;Integrated Security=True;MultipleActiveResultSets=True" providerName="System.Data.SqlClient" />
<add name="EcfSqlConnection" connectionString="Data Source=(LocalDb)\MSSQLLocalDB;AttachDbFilename=C:\Users\Alex\Documents\Visual Studio 2015\TEST\PhoneShop\PhoneShop\App_Data\EcfSqlConnection_5a171677.mdf;Initial Catalog=EcfSqlConnection_5a171677;Connection Timeout=60;Integrated Security=True;MultipleActiveResultSets=True" providerName="System.Data.SqlClient" />
Result. I have two site. But I don't have link in admin panel.
Web sites
#141446
Edited, Nov 16, 2015 11:20
As I mentioned, you need to install http://nuget.episerver.com/en/OtherPages/Package/?packageId=EPiServer.Commerce.UI.ManagerIntegration
Regards,
/Q
#141448
Nov 16, 2015 11:38
I installed this package. No results.
#141449
Nov 16, 2015 12:03
Looking carefully to your steps again, I think you misunderstood something:
- For the front end site, you'll need to install EPiServer.Commerce and EPiServer.Commerce.UI.ManagerIntegration
- For the backend site (Commerce Manager), you'll need to install EPiServer.CommerceManager
- In the web.config of front end site, make sure the you set the url to your Commerce Manager site in appSettings/CommerceManagerLink. If the value for this key is empty then the menu to Commerce Manager will be hidden.
/Q
#141450
Nov 16, 2015 12:06
Yes. But not work.
#141459
Nov 16, 2015 12:55
What does not work for you? You followed the instructions in the previous post?
#141461
Nov 16, 2015 13:14
Yes. I followed the instructions in the previous post. I don't see link in admin panel.
#141619
Nov 16, 2015 16:02
I just did the steps myself and the menu works fine for me.
The CommerceManagerLink was automatically updated when I install CommerceManager package to second site.
Regards,
/Q
#141622
Nov 16, 2015 16:30
No. But I solved problem.
<add key="CommerceManagerBinPath" value="C:\...\Solution\CommerceManager\Bin\" />
<add key="CommerceManagerSharedPath" value=" C:\...\Solution\CommerceManager \" />
<add key="CommerceManagerApplicationName" value="ECApplication" />
<add key="CommerceManagerLink" value="http://localhost:64590/Apps/Shell/Pages/default.aspx" />
Thank you for your help and patience.
#141660
Nov 17, 2015 17:46
