If you're using 7.11 or later (IIRC), you can access MetaDataType.DictionaryMultiValue and MetaDataType.DictionarySingleValue via Content API, they are just a List<string> and a string, respectively. StringDictionary is still not supported.
Regards,
/Q
Is there any way that one could fetch dictionary metafields from nodes/products/variants using the CatalogContentProvider?
Or is the ICatalogSystem the only way to retrieve dictionary values?
Thanks.
