Which is version you are using? And are you login to Commerce Manager directly, or you login via iframe in CMS?
Regards.
/Q
Hi Quan
i use Episerver 7.5 and i tried both to login Commerce Manager directly and also in CMS but same result.
For 7.5, it's required that Apps folder (which path is defined in CommerceManagerSharedPath) to be a virtual directory under Commerce Manager IIS site. Do you check in IIS Manager to see if it's there?
Regards.
/Q
I got error below in login page to Episerver commerce manager but Login.aspx is in the folder . All folders and config value(CommerceManagerBinPath,CommerceManagerSharedPath,CommerceManagerApplicationName,CommerceManagerLink) are in right place as it should be in web.config. I have no idea why i got that error and where should i check more?
The resource cannot be found.Description: HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable. Please review the following URL and make sure that it is spelled correctly.
Requested URL: /Apps/Shell/Pages/Login.aspx
