Log4net issue
Episerver is not writing custom and internal logs together. It writes custom logs with the below code in Application_start event but not internal logs. Without the below code it writes internal logs but not custom logs. Its always either or
var logfile = new System.IO.FileInfo(HttpContext.Current.Server.MapPath("log4net.config"));
XmlConfigurator.ConfigureAndWatch(logfile);
 Also in the log4net trace I noticed its trying to load old version of log4net (1.2.10.0) though we upgraded to 1.2.11.0 version.
Where should I check the Episerver log4net versions? Or how can I find out where its using the older version ?
Please help!
#88468
Jul 14, 2014 23:01
The version of log4net should be configurable via assembly dependentAssembly section in web.config.
Add/modify this section in your web.config:
Regards.
/Q
#88473
Edited, Jul 15, 2014 6:08
Hi Quan, I did try changing the dependentAssembly in web.config to
but NO luck.
Also found through Process Explorer, a few process using the old version 1.2.10.0 of log4net from GAC including Episerver.scheduler.svc and noticed these are running on .net framework 2.0.
Trying many things, finally we decided to use a separate config and log file for custom logs and another config and log file for internal logs . Which does what we need ! But still curious why is it still using old version of log4net in a few places.
On a side note I noticed the base Episerver folder has old 1.2.10.0 dlls which I replaced to new 1.2.11.0 that didnt help either.
Please share any thoughts or ideas you may have!
Thanks in advance!
#88519
Jul 15, 2014 18:21
Note that the publicKeyToken should be 1b44e1d426115821 instead of 669e0ddf0bb1aa2a. You might want to take a look here:
http://stackoverflow.com/questions/8743992/how-do-i-work-around-log4net-keeping-changing-publickeytoken
/Q
#88523
Jul 16, 2014 1:11
Unfortunately It didnt work in our case.
The issue was C:\EpiServer\eCommerceFramework\5.2\XavierCommerceManager\Sites\IntegrationService\bin  had the old version of dll and replacing that with the new version solved the issue.
Thanks and appreciate your help Quan!
#88553
Jul 16, 2014 18:16
