How to add meta fields to Cart
Guys, could you provide an example of configurations that allow meta fields "MetaField1" for ecommerce Cart object:
cart0["MetaField1"] = 5; //for example
As I understand I have to declare metafield somehow first to use it in application.
Thank you!
#88461
Jul 14, 2014 16:12
The answer of David is for the administration/manual approach. You can also do it programmatically, by those API:s
Mediachase.MetaDataPlus.Configurator.MetaField.Create(...)
Mediachase.MetaDataPlus.Configurator.MetaClass.AddField(MetaField,...)
Regards.
/Q
#88472
Jul 15, 2014 6:05
David, Quan, thank you for the answers. David, yes, I have to do it via API.
Quan, I have an issue related to Mediachase.MetaDataPlus.Configurator.MetaClass.AddField - it always adds row with SystemMetaClassId = 0 to MetaField table. But I need to specify the class (otherwise contraints exception about uniqe (Name, SystemMetaClassId) pair is thrown). But I haven't found any methods to specify SystemMetaClassId on creation. Maybe you can recommend something?
#88489
Jul 15, 2014 11:26
You don't have to specify SystemMetaClassId on creation. That should be done automatically. Can you post your code here?
Regards.
/Q
#88492
Jul 15, 2014 11:37
var mc = MetaClass.Load(OrderContext.MetaDataContext, OrderConfiguration.Instance.MetaClasses.ShoppingCartClass.Name);
var metaField = MetaField.Create(MetaDataContext.Instance, metaFieldCreatingParam.Namespace, metaFieldCreatingParam.Name, metaFieldCreatingParam.FriendlyName, metaFieldCreatingParam.Description, metaFieldCreatingParam.MetaDataType, metaFieldCreatingParam.Length, metaFieldCreatingParam.AllowNulls, metaFieldCreatingParam.MultiLanguageValue, metaFieldCreatingParam.AllowSearch, metaFieldCreatingParam.IsEncrypted);
mc.AddField(metaField);
Should this code set SystemMetaClassId field? Possible field SystemMetaClassId is something obsolete, since MetaClassMetaFieldRelation table exists?..
#88494
Jul 15, 2014 11:46
Yes, it should work. The relations between metaclasses and metafields are stored in MetaClassMetaFieldRelation, and I don't see any problem with your code. What's the error you got?
/Q
#88498
Jul 15, 2014 12:32
There is no problems with the code if I don't have DisplayName in MetaField table yet, but there is problem that I have already metafiled with Name="DisplayName" and SystemMetaClassId = 0, but let's say it doesn't suit my purposes because of length. Can I create another metafield called "DisplayName" with another length? Is it possible?
So could you please clarify conception a little: now all metafields in MetaField table are "globally" defined? I mean that for example if I need assign DisplayName field to some metaclass and this field already exists in MetaField table, should I use this existent field? I am not able to create another one with other parameters (like length, isNullable, etc) that fits the needs of some concrete metaclass, am I right?
#88500
Jul 15, 2014 12:45
So why not just delete the old Display Name then create a new one? Having two meta fields with same name is not recommended.
Regards.
/Q
#88522
Jul 16, 2014 1:09
#88542
Jul 16, 2014 14:04
Quan, ok, understood. Thank you for the comments.
#88543
Jul 16, 2014 14:04
