Basically in new asset system, an asset is a content, so you can use the EPiServer Search API:s to search for it. Here's an example how:
http://world.episerver.com/Blogs/Eric-Herlitz/Dates/2013/1/Using-EPiServer-Search-in-EPiServer-7-MVC/
Regards.
/Q
Im not sure how to continue from here, how do I create a CommerceMedia from a MediaData item? What is an assetId?
var contentRepository = ServiceLocator.Current.GetInstance<IContentRepository>();
var loader = ServiceLocator.Current.GetInstance<IContentLoader>();
var referenceConvertor = ServiceLocator.Current.GetInstance<ReferenceConverter>();
var variant = loader.Get<VariationContent>(referenceConvertor.GetContentLink(catalogEntryDto.CatalogEntry[0].Code)); // Get variant from new API
var entry = variant.LoadEntry();
var contentId = GetContentIDFronFileName(row.VariationImageName);
var image = loader.Get<MediaData>(new ContentReference(contentId));
variant.CommerceMediaCollection.Add(new CommerceMedia(??????));
I don't know where you get that code. What is the goal you're trying to archive?
/Q
When importing products to Episerver i want the product to make a connection with its default image defined by a full filename.
This is the old code for the project
private void SetVariationImage(CatalogEntryDto catalogEntryDto, MaterialRow row)
var culture = MetaDataContext.DefaultCurrent.Language;
var cultureInfo = new CultureInfo(culture);
var variationWithParent = CatalogHelper.GetVariationWithParent(string.Concat(row.MaterialId, "_", row.SalesOrgId), cultureInfo);
if (variationWithParent != null && variationWithParent.ParentEntry != null)
var indexList = new List<int>();
for (var i = 0; i < catalogEntryDto.CatalogItemAsset.Count; i++)
if(catalogEntryDto.CatalogItemAsset[i].GroupName.Equals(AssetGroup.PrimaryImage))
indexList.Add(i);
foreach (var index in indexList)
catalogEntryDto.CatalogItemAsset[index].Delete();
CatalogContext.Current.SaveCatalogEntry(catalogEntryDto);
if (!string.IsNullOrEmpty(row.VariationImageName))
var assetEntities = EntityManager.List<EntityObject>(FolderElementEntity.ClassName, FilterElement.EqualElement(FolderElementEntity.FieldName, row.VariationImageName));
var temp = assetEntities.FirstOrDefault();
if (temp != null)
var primaryKeyId = temp.PrimaryKeyId;
if (primaryKeyId != null && primaryKeyId.Value.ToString() != null)
while (true)
var exist = _productRepo.CatalogAssociationIdExist(1, catalogEntryDto.CatalogEntry[0].CatalogEntryId);
if (!exist) break;
var newPrimaryImageAssetRow = catalogEntryDto.CatalogItemAsset.NewCatalogItemAssetRow();
newPrimaryImageAssetRow.AssetKey = primaryKeyId.Value.ToString();
newPrimaryImageAssetRow.AssetType = "file";
newPrimaryImageAssetRow.CatalogNodeId = 1; //TODO double-check
newPrimaryImageAssetRow.CatalogEntryRow = catalogEntryDto.CatalogEntry[0];
newPrimaryImageAssetRow.GroupName = AssetGroup.PrimaryImage;
newPrimaryImageAssetRow.SortOrder = 0;
catalogEntryDto.CatalogItemAsset.AddCatalogItemAssetRow(newPrimaryImageAssetRow);
It's not entirely clear for me what you're trying to do, but basically, you can keep either way - keep your old code, only note the AssetKey is now obsolete (in 7.8.x) and you need to switch to AssetLink instead, or switch to new CommerceMedia way.
If you want to use CommerceMedia, it's basic class with this information. I'll assume you're using 7.5:
var commerceMedia = new CommerceMedia()
AssetKey = //GUID of the image
AssetType = "file"
GroupName = //Something you like
SortOrder = //Something you like
Then you can add it to CommerceMediaCollection as normal.
Regards.
/Q
I'm trying to save the variant, but im getting the following error
{System.ArgumentNullException: The provided content link does not have a value.
Parameter name: contentLink
at EPiServer.Core.DefaultContentLoader.Get[T](ContentReference contentLink, ILanguageSelector selector)
at EPiServer.Commerce.Validation.MissingStartingPointLanguageValidator.<>c__DisplayClass2.<ShouldShowWarning>b__1(ICommerceRouter route)
at System.Linq.Enumerable.Any[TSource](IEnumerable`1 source, Func`2 predicate)
at EPiServer.Commerce.Validation.MissingStartingPointLanguageValidator.ShouldShowWarning(CatalogContentBase content)
at EPiServer.Commerce.Validation.MissingStartingPointLanguageValidator.Validate(CatalogContentBase instance)
at EPiServer.Validation.ValidationService.ValidateRecursively(Object instance, HashSet`1 visitedInstances)
at EPiServer.Core.ContentProvider.Validate(IContent content, SaveAction action)
at EPiServer.Core.DefaultContentRepository.Save(IContent content, SaveAction action, AccessLevel access)
at Avensia.Bona.Integration.ProductRefinement.MaterialProcessor.SetVariationImage(CatalogEntryDto catalogEntryDto, MaterialRow row) in c:\Projects\Avensia.Bona\Avensia.Bona.Integration.ProductRefinement\MaterialProcessor.cs:line 348
at Avensia.Bona.Integration.ProductRefinement.MaterialProcessor.SetVariationMetaProperties(MaterialRow row, CatalogEntryDto entryDto, IEnumerable`1 catalogLanguages) in c:\Projects\Avensia.Bona\Avensia.Bona.Integration.ProductRefinement\MaterialProcessor.cs:line 319
at Avensia.Bona.Integration.ProductRefinement.MaterialProcessor.ProcessCatalogEntry(MaterialRow row, CatalogEntryDto entryDto, Int32 catalogNodeId) in c:\Projects\Avensia.Bona\Avensia.Bona.Integration.ProductRefinement\MaterialProcessor.cs:line 85
at Avensia.Bona.Integration.ProductRefinement.MaterialProcessor.ProcessMaterial(MaterialRow row) in c:\Projects\Avensia.Bona\Avensia.Bona.Integration.ProductRefinement\MaterialProcessor.cs:line 73
at Avensia.Bona.Integration.ProductRefinementService.RefineProductFile(ProductRefinementFile file) in c:\Projects\Avensia.Bona\Avensia.Bona.Integration\ProductRefinementService.cs:line 33
at Avensia.Bona.Site.ScheduledJobs.ProductIntegration.RunProductRefinmentForFile(ProductRefinementFile file) in c:\Projects\Avensia.Bona\Avensia.Bona.Site\ScheduledJobs\ProductIntegration.cs:line 80
at NHibernate.Linq.TypeHelperExtensionMethods.ForEach[T](IEnumerable`1 query, Action`1 method)
at Avensia.Bona.Site.ScheduledJobs.ProductIntegration.Execute() in c:\Projects\Avensia.Bona\Avensia.Bona.Site\ScheduledJobs\ProductIntegration.cs:line 54}
using
var variant = (VariationContent)loader.Get<VariationContent>(referenceConvertor.GetContentLink(catalogEntryDto.CatalogEntry[0].Code)).CreateWritableClone(); // Get variant from new API
variant.CommerceMediaCollection.Add(new CommerceMedia(image.ContentGuid.ToString(), "file", "Primary", 0, 0));
contentRepository.Save(variant, SaveAction.Publish, AccessLevel.NoAccess);
The problem you're seeing seems to be unrelated to the asset problem. I suspect the issue was RouteStartingPoint, which was not properly configured for the current language.
What's the code you're using to register the Hierarchical router for Commerce? I would suggest to comment the code related to asset and run to see.
/Q
Hi, we're seeing the same issue here when trying to save a product. The error is:
1: Error Description: The provided content link does not have a value.
1: Source: EPiServer
1: Stack Trace: at EPiServer.Core.DefaultContentLoader.Get[T](ContentReference contentLink, ILanguageSelector selector)
1: at EPiServer.Commerce.Validation.MissingStartingPointLanguageValidator.<>c__DisplayClass2.b__1(ICommerceRouter route)
1: at System.Linq.Enumerable.Any[TSource](IEnumerable`1 source, Func`2 predicate)
1: at EPiServer.Commerce.Validation.MissingStartingPointLanguageValidator.ShouldShowWarning(CatalogContentBase content)
1: at EPiServer.Commerce.Validation.MissingStartingPointLanguageValidator.Validate(CatalogContentBase instance)
1: at EPiServer.Validation.ValidationService.ValidateRecursively(Object instance, HashSet`1 visitedInstances)
1: at EPiServer.Core.ContentProvider.Validate(IContent content, SaveAction action)
1: at EPiServer.Core.DefaultContentRepository.Save(IContent content, SaveAction action, AccessLevel access) >
The code we're using to register the hierarchical router is:
CatalogRouteHelper.MapDefaultHierarchialRouter(RouteTable.Routes, () => ContentReference.StartPage, false);
If we remove this line the product will save ok but we need hierarchical routing enabled for the site.
We used to get assets for a product by using the full file name for the asset
How do i get the same asset by file name using the new asset system? Can i search by using a propertycriteria?
