I've found the solution. To get information about the current provider for BlobStorage, use BlobStorage.Provider and then cast it into PublicDiskStorageProvider to access the basePath property.
var blobStorage = (PublicDiskStorageProvider)BlobStorage.Provider;
var file = new FileStream(blobStorage.BasePath + header.BlobUid.ToString("N") + @"\" + header.Name, FileMode.Open, FileAccess.Read);
Brgds
Jonas
I'm using EPiServer Commerce 1 and I need to get access to the basePath attribute defined in baf.config for the default storage provider PublicDiskBlobStorageProvider. Is there a way to get to this using the EPiServer API, or do I need to parse the baf.config file "manually" and find the wanted element?
Any tips?
Brgds
Jonas
