MetaStringDictionary property from code
I am creating a site with EPiServer Commerce 7.5 and I want to declare my variation metaclass from code.
Everything works fine except I have two fields that is of the StringDictionary in Commerce.
How do i declare those properties and decorate them so that they are interpreted as the type stringdictionary?
As of i now i have only done this:
[Display(Name = "OffersText")]
public virtual MetaStringDictionary OffersText { get; set; }
But I get the following error:
The type Mediachase.MetaDataPlus.MetaStringDictionary can not be mapped to a MetaDataType
I have also tried wth the type StringDictionary but i get the following error.
#85852
May 07, 2014 10:50
In 7.5, the dictionary types are not supported by Catalog contents. You need to update to latest nuget package (7.7.2 or later) to enable the support.
Regards.
/Q
#85886
May 08, 2014 7:16
Thanks for replying.
I have updated project through nuget and it is still not working. Is it sufficient just declaring the property like above, or do I need to decorate the property with a specific attribute?
I have version 7.7.2.24 of Mediachase.
#85891
May 08, 2014 9:18
I'm sorry to read it too fast. The dictionary types we're supporting are Single and Multi dictionary. The StringDictionary, as it has some special characteristics, will not be supported for now - You'll need to edit it via CM.
Thank you.
/Q
#85893
May 08, 2014 10:15
Ok, so I will not be able to handle the string dictionary as Content. The reason is that I am writing an import job, that creates variantions and add them to the catalog. So basically I would need to either change the datatype to a multivalue dictionary. Or handle the standard properties as content and then pull out the old trusted MetaHelper and edit them the same way as before.
#85895
May 08, 2014 10:25
So how do you decorate the property for Single and Multi dictionary? Neither of following is working:
public virtual MetaDictionary SchoolType { get; set; }
public virtual DictionarySingleEditorDescriptor MySingleDictionaryProperty { get; set; }
Can't seem to find any info on what to use for the Dictionary properties?
I'm running Commerce 7.7.
/J
#112665
Nov 03, 2014 13:56
Found it:
[BackingType(typeof(PropertyDictionarySingle))]
public virtual string MyTestDictionary { get; set; }
[BackingType(typeof(PropertyDictionaryMultiple))]
public virtual ItemCollection<string> MyTestMultiDictionary { get; set; }
/J
#112667
Nov 03, 2014 14:08
