CartHelper.AddEntry creates order forms based on cart name instead of using Cart.DefaultName
tss
tss
Hi right now the CartHelper creates an OrderForm named by the current cart name if no OrderForm exists
wouldn't it be better if the AddEntry() called GetOrderForm() to use the same logic for adding order forms in both places,
GetOrderForm() creates a OrderForm named "Default" if no order form exists.
so its quite easy to make a mistake right now and create a basket with two order forms.
#82636
Mar 17, 2014 15:12
Thank you for noticing this. We'll file a bug report to it and see what we can do to improve the situation.
Thanks.
/Q
#82658
Mar 18, 2014 8:11
Your issue have been release in update 10, you can check it on: http://world.episerver.com/Documentation/Release-Notes/?packageFilter=EPiServer.Commerce.Core
Regards,
//Son Do
#84751
Edited, Apr 07, 2014 12:15
