Add Notes dynamically
How do you add notes dynamically to a Cart?
I have used the following code yet the Notes are never added
OrderNote on = new OrderNote(); on.Detail = AnswerRef; on.OrderNoteId = Convert.ToInt32(QuestionRef); on.Title = AnswerRef; on.Type = "Custom"; on.Created = DateTime.Now; ch.Cart.OrderNotes.Add(on);
ch being a new CartHelper - the code comes afer an entry is added to the cart (ch)
eg:
ch.AddEntry(variant, 1, false, warehouseCode, new CartHelper[] { wishList });
Jon
#83210
Mar 27, 2014 14:49
I looks like you need to call
ch.Cart.AcceptChanges() after that code to make sure it got saved to database. Otherwise it'll be lost when GC kicks in.
Regards.
/Q
#83215
Mar 27, 2014 15:24
Yes, I do this too and nothing happens - the AddNew() method works but not Add(on).
#83228
Mar 27, 2014 16:54
AddNew() works but then you can't update the new OrderNote
#83229
Mar 27, 2014 16:55
AddNew() leaves blank entries into the Notes section and does not save the updates - ch.Cart.AcceptChanges() doesnt update the Notes  - any ideas?
#83231
Mar 27, 2014 17:08
Have you tried AddNew first and finally AcceptChanges:
OrderNote on = ch.Cart.OrderNotes.AddNew();
on.Type = "Custom";
ch.Cart.AcceptChanges();
#83239
Mar 27, 2014 20:30
This is great but it still doesnt save the OrderNote. Is there any other way that this can be done?
#83251
Mar 28, 2014 9:06
Just to be clear, do you want to update an existing OrderNote or create a new one?
I ask because you are trying to set OrderNoteId:
If you want to update an existing note I think you need to find it by iterating ch.Cart.OrderNotes and change the wanted note and AcceptChanges. If you want to create a new note then don't set the OrderNoteId.
#83256
Mar 28, 2014 9:43
Arrr! I see - yes I want to create a new Note. This sounds good - I'll give it a go :) Thanks
#83257
Mar 28, 2014 9:45
Yes - just tested it and it works - amazing - many thanks :)
#83260
Mar 28, 2014 10:04
