How to setup roles in initialize module?
I would like to setup commerce roles in the initialize module (Commerce 7.5 MVC).
But I get the error: System.NullReferenceException: Object reference not set to an instance of an object.
What should be added to the
[InitializableModule]
    [ModuleDependency(typeof(EPiServer.Commerce.Initialization.InitializationModule))]
    public class RoleInitializationModule : IInitializableModule
            var securityManagerInstance = SecurityContext.Current.SecurityManagerInstance;
            securityManagerInstance.CreateRole("test", Enumerable.Empty<SecurityPermission>());
        public void Preload(string[] parameters) { }
#81251
Feb 12, 2014 15:56
The error you got was because SecurityContext.Current can be initialized properly, which itself caused by SqlContext is not properly initialized.
You can workaround this case by adding this:
            DataContext.Current = new DataContext(ConfigurationManager.ConnectionStrings["EcfSqlConnection"].ConnectionString);
            SqlContext.Current = DataContext.Current.SqlContext;
Regards.
/Q
#81264
Feb 13, 2014 4:38
Thank you )
#81268
Feb 13, 2014 8:04
