Hi Simon
I'm getting the same error. Did you find a solution to the problem?
Regards
Anders
The problem happened with Commerce Manager update 4 (.446.x) and was registered as a bug. This was fixed in next release (in testing phase). We understand that this is causing trouble and will release updates ASAP.
Thank you for your understanding and co-operation.
Regards.
/Q
I've applied EPiServer 7.5 update 4 to Commerce Manager using the instructions found on this page http://world.episerver.com/Documentation/Items/Installation-Instructions/Installing-EPiServer-updates/. Then, when I try to add a new payment method I get an application error, which is shown below.
Cannot find a type of name Mediachase.Commerce.Orders.IPaymentGateway within the plugins or the common library.
[ArgumentException: Cannot find a type of name Mediachase.Commerce.Orders.IPaymentGateway within the plugins or the common library.]
System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) +14543138
System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) +622
Mediachase.Web.Console.Common.RemoteLoader.GetSubclasses(String baseClass) +0
Mediachase.Web.Console.Common.ReflectionHelper.GetClassesBasedOnTypeInSiteDir(Type assemblyType, String path) +455
Mediachase.Commerce.Manager.Order.Payments.Tabs.PaymentMethodEditBaseTab.BindClassNames() +220
Mediachase.Commerce.Manager.Order.Payments.Tabs.PaymentMethodEditBaseTab.BindForm() +75
System.Web.UI.Control.LoadRecursive() +71
System.Web.UI.Control.LoadRecursive() +190
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3178
What could be the cause of this problem?
Kind regards,
Simon
