CatalogRouteHelper respons 404 with blank page
I'm running an application on EpiServer Commerce 7.7.2 and I'm trying to configure 404 error page in web.config.
But when I test a page that doesn't exists then it just returns a blank page and does not redirect to my 404 page.
I suspect that its the CatalogRouteHelper which is causing this.
We are using the CatalogRouteHelper for the routing for the products in EpiServer Commerce.
http://world.episerver.com/documentation/Class-library/?documentId=commerce/8/ACBC5726
Anyone with a workaround or a solution to this?
Thanks in advance.
/M
#114439
Dec 11, 2014 15:49
Is 404 a static HTML Page or an EPiServer page?
/K
#114447
Dec 11, 2014 17:48
Basically CatalogRouteHelper only register the HierarchicalCatalogPartialRouter. It should not affect 404 handling.
Just tested on our sample site, when I try to access non-existed product, it throws 404 error as expected. What is your registration for the route and for the custom error page?
Regards.
/Q
#114457
Dec 12, 2014 3:51
@K Khan: We are using an EpiServer page.
@Quan Mai:
We have only set this in our InitializationModule
MapRoutes(RouteTable.Routes);
private static void MapRoutes(RouteCollection routes)
CatalogRouteHelper.MapDefaultHierarchialRouter(routes, true);
public void Uninitialize(InitializationEngine context) { /*uninitialize*/}
public void Preload(string[] parameters) { }
I've set up the customerror in web.config as follows:
<customErrors mode="On" >
<error redirect="/404" statusCode="404"/>
</customErrors>
#114463
Dec 12, 2014 9:31
I'm not sure if you show simplified configuration, but shouldn't the redirect value be "/404.html" instead?
Do you have any thing on Global.asax?
/Q
#114465
Dec 12, 2014 9:39
Actually that is the only configuration we got.
I've tried to set a static file as well in web.config customerrors but its the same issue.
Is there something else we have forgot to configure?
/M
#114467
Dec 12, 2014 9:52
I found what I did wrong.
I actually forgot to set the correct configuration in web.config.
<httpErrors errorMode="Custom" existingResponse="Replace">
<clear/>
<error statusCode="404" path="/404/" responseMode="ExecuteURL" />
</httpErrors>
#114469
Dec 12, 2014 10:09
