Create decimal metafield in code and add to metaclass - scale not set
Hi Guys,
I'm trying to create a metafield in code and add this to a metaclass, I've come up with the following code, which works, however the scale for the decimal isn't set, this is always zero.
Any ideas, am I doing this correectly?
Thanks, Mark
var metaClassContext = MetaClass.Load(OrderContext.MetaDataContext, metaClassName);
if (metaClassContext.MetaFields[metaFieldName] != null)
    return;
var metaField = MetaField.Load(MetaDataContext.Instance, metaFieldName);
if (metaField == null)
    metaField = MetaField.Create(MetaDataContext.Instance, metaClassNamespace, metaFieldName, metaFieldFriendlyName,
        metaFieldDescription, metatDataType, metaDataLength, allowNulls, false, false, false);
    if (metatDataType == MetaDataType.Decimal)
        metaField.Attributes[MetaFieldAttributeConstants.MdpPrecisionAttributeName] = decimalPrecision.ToString(CultureInfo.InvariantCulture);
        metaField.Attributes[MetaFieldAttributeConstants.MdpScaleAttributeName] = decimalScale.ToString(CultureInfo.InvariantCulture);
metaClassContext.AddField(metaField);
#112552
Oct 30, 2014 5:50
Bugger... I've just worked this out...
Code is fine, the issue was because the MetaField already existed, i.e. this field was initially created without scale, I removed the field from the MetaClass and ran this again but didn't see it being updated, once I removed the MetaField form the MetaField table and ran the code again, everythign worked as expected.  So user error...  Anway I guess this code could be enhanced to check for the MetaField already existing and update that.
So hope this helps someone else...
#112554
Oct 30, 2014 6:04
