Get Product URL from Guid, id or Code
Hi, Im using 7.5 and need to get a Products URL by using it's GUID, ID or code or even name.
Is this at all possible?
Jon
#80249
Jan 17, 2014 14:21
You would use the ReferenceConverter to get the ContentLink for your product. You could then use the CMS API:s to load the the product as content, and get the URL that way.
See the "Load a product" sample in this article, http://world.episerver.com/Documentation/Items/Developers-Guide/EPiServer-Commerce/751/Content/Catalog-content-provider/.
Regards
Per Gunsarfs
#80251
Jan 17, 2014 14:58
EPiServer Commerce support a variable ways to get product url from its GUID, ID or code, but unfortunately not name - as many products can have "similar" name.
- If you already have GUID, you can use IContentRepository and UrlResolver to get the product link
- If you already have an ID, you can follow instructions from Per above to get the product link
- If you have the code, it's a bit tricky, you we need to use ICatalogSystem.GetCatalogEntryDto to get the CatalogEntryDto, then the Id. In next releases we might add a new, more convinient way to get the id from the code.
- If you have the name, you can use search to get the exact code/id, as name is not required to be unique then there is no direct way to get the url.
Regards.
/Q
#80259
Jan 18, 2014 8:52
To add to Quan's answer, there is acutally an overload of ReferenceConverter.GetContentLink which accepts the code, so no need to use the DTO:s directly in this case.
#80263
Jan 20, 2014 8:23
