Hi there,
I am currently developing a commerce solution based on EPiServer Commerce an need to extend the "Build your own discount" fields on a Shipment.
I tried to follow the Blog post by Shannon Gray without any luck. To simplify the solution (after it didn't work with meta field on Shipment) i tried to implement the LineItem "Taste" property - again with no luck.
The problem is when i try to use the property in a Promotion, there is no oppotunity to choose either my Shipment property or the LineItem Taste property.
Do you guys (and girls) have any suggestions?
I have disabled all cache in Commerce (incl. ecf.marketing.config) and restarted the server many times.
Best Regards,
Casper Rasmussen
