Commerce database schema deployment
Is there out of the box way to install Commece database schema without installing Commerce site?
I know that that is easy for Cms schema. There is corresponding action in Deployment Center for CMS, but there is nothing similar for Commerce.
#78955
Dec 05, 2013 15:19
I thought there was an option added in this version to allow this but I do not see it.  If you want to install a database you can run the following script
C:\Program Files (x86)\EPiServer\CMS\7.5.394.2\Install\Modules\EPiServer Commerce 7.5.394.2\ECF\Data\SqlScripts\Helpers\Setup.bat with the following parameters from the bat file
set dbAdmin=%1
set dbAdminPass=%2
set dbServer=%3
set dbName=%4
set dbUser=%5
set dbPass=%6
set appName=%7
The script will create the database and the set the specified dbuser and dbpass as the dbo of the newly created database.
#79190
Dec 10, 2013 19:43
