Server Error in '/' Application - License has expired
Does anyone know hos to fix this issue.  The Error occurs just after the Commerce Login screen.
I have created (serval) Parter Developer Liceses and copied to EPiServer website and Commerce website.
I have created EPiServer Incident at the servicedesk, but no result..
License has expired.
Exception Details: EPiServer.Licensing.LicenseException: License has expired.
Source Error:
Stack Trace:
[LicenseException: License has expired. ]
   EPiServer.Licensing.LicenseData.Validate() +580
   System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) +0
   System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) +808
   System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) +38
   System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams) +2798
   Mediachase.Licensing.License.Load(String licenseData) +1167
   Mediachase.Licensing.LicenseManager.LoadLicense(String licenseData) +59
   Mediachase.Licensing.LicenseManager.LoadLicenseForComponent(String componentId) +134
   Mediachase.Licensing.LicenseManager.GetLicense(String componentId) +114
   Mediachase.Licensing.CommerceLicense.get_Instance() +111
   Mediachase.Licensing.CommerceLicense.CheckLicensing(Boolean useCache) +47
   Mediachase.Licensing.CommerceLicenseProvider.GetLicense(LicenseContext context, Type type, Object instance, Boolean allowExceptions) +28
   System.ComponentModel.LicenseManager.ValidateInternalRecursive(LicenseContext context, Type type, Object instance, Boolean allowExceptions, License& license, String& licenseKey) +277
   System.ComponentModel.LicenseManager.Validate(Type type, Object instance) +82
   Mediachase.Commerce.Manager.Apps.Shell.Modules.UpTemplate.Page_Load(Object sender, EventArgs e) +54
   System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +25
   System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +42
   System.Web.UI.Control.OnLoad(EventArgs e) +132
   System.Web.UI.Control.LoadRecursive() +66
   System.Web.UI.Control.LoadRecursive() +191
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2428
Version Information: Microsoft .NET Framework Version:2.0.50727.4984; ASP.NET Version:2.0.50727.4971
#77604
Nov 21, 2013 13:58
Tried doing an iisreset after updating the license file? Do you have EPiServer.Licensing.dll in your bin folder?
Frederik
#77608
Nov 21, 2013 14:41
Hi Frederik
I have tried to do a iisreset with admin and I have EPiServer.Licensing.dll in /bin
It's EPiServer 6.0 (Not R2) and Commerce 5.1
#77610
Nov 21, 2013 14:53
