It´s report definition file (.rdlc) ..\Shared\Apps\Reporting\Reports. Open the "InvoiceRecieptReport.rdlc" in VS and change it in the editor.
I already tried that but I would like to add a custom MetaField (CustomerContact object) on the invoice report. How can I do that, is it necessary to change the data source of the report?
You mean a custom field that you have added to the contact class? The name of the customer is already in the dataset.
I had a look at it and tried to fiddle directly with the xml in the report .rdlc. Additionally, VS doesn’t behave well with the report, I didn't get the results I expected. You probably have to have a look at changing the data source.
Any idea, how to configure a new data source for the report? If I decompile the dll's it seems that the data source is hardcoded in the source.
Our official answer for customizations made to Commerce Manager is it's not officially supported.
I personally can see how to do it, and I might write about that if time permits, but if it's urgent you should turn to expert services for help.
Does anybody know how you can edit the packing slip with additional fields?
Thanks.
Patrick
