Failed Installing Commerce into an existing CMS site
using CMS 6 R2
using Commerce R2 SP2
i can setup clean installs of CMS and then install commerce & then enoteca sample site and all works as expected
but try to install it on an existing site (that contains alloytech sample site) i get the following install error:-
Error - The WriteObject and WriteError methods cannot be called from outside the overrides of the BeginProcessing, ProcessRecord, and EndProcessing methods, and only from that same thread. Validate that the cmdlet makes these calls correctly, or please contact Microsoft Support Services.
and then the log:-
Begin-EPiBulkInstall transaction of Commerce installation
Started a transacted install
Installing Common Framework features to site
D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI
Install Common Framework on selected site
productPath: C:\Program Files (x86)\EPiServer\Framework\6.2.267.1\
Executing database script "C:\Program Files (x86)\EPiServer\Framework\6.2.267.1\Upgrade\Database\sql\0006_0000_0318_0113to0006_0002_0127_0000.sql"
Not executing database script "C:\Program Files (x86)\EPiServer\Framework\6.2.267.1\Upgrade\Database\sql\0006_0000_0318_0113to0006_0002_0127_0000.sql" because it has already been executed.
Executing database script "C:\Program Files (x86)\EPiServer\Framework\6.2.267.1\Upgrade\Database\sql\0006_0002_0128_0000to0006_0002_0130_0000.sql"
Not executing database script "C:\Program Files (x86)\EPiServer\Framework\6.2.267.1\Upgrade\Database\sql\0006_0002_0128_0000to0006_0002_0130_0000.sql" because it has already been executed.
Executing database script "C:\Program Files (x86)\EPiServer\Framework\6.2.267.1\Upgrade\Database\sql\0006_0002_0131_0000to0006_0002_0138_0000.sql"
Not executing database script "C:\Program Files (x86)\EPiServer\Framework\6.2.267.1\Upgrade\Database\sql\0006_0002_0131_0000to0006_0002_0138_0000.sql" because it has already been executed.
Executing database script "C:\Program Files (x86)\EPiServer\Framework\6.2.267.1\Upgrade\Database\sql\0006_0002_0139_0000to0006_0002_0228_0000.sql"
Not executing database script "C:\Program Files (x86)\EPiServer\Framework\6.2.267.1\Upgrade\Database\sql\0006_0002_0139_0000to0006_0002_0228_0000.sql" because it has already been executed.
Executing database script "C:\Program Files (x86)\EPiServer\Framework\6.2.267.1\Upgrade\Database\sql\0006_0002_0229_0000to0006_0002_0256_0000.sql"
Not executing database script "C:\Program Files (x86)\EPiServer\Framework\6.2.267.1\Upgrade\Database\sql\0006_0002_0229_0000to0006_0002_0256_0000.sql" because it has already been executed.
installedVersion: 6.2.267.1
frameworkVersion: 6.2.267.1
Skipping web config modification of EPiServer Framework (6.0.318.113 < 6.2.267.
1)
Skipping web config modification of EPiServer Framework (6.1.79.0 < 6.2.267.1)
Skipping web config modification of EPiServer Framework (6.2.267.1 < 6.2.267.1)
Executing database script "C:\Program Files (x86)\EPiServer\CommonFramework\4.1.517.380\Upgrade\Database\sql\0002_0003_0001_0000to0004_0001_0517_0380.sql"
Not executing database script "C:\Program Files (x86)\EPiServer\CommonFramework\4.1.517.380\Upgrade\Database\sql\0002_0003_0001_0000to0004_0001_0517_0380.sql" because it has already been executed.
Copied Castle.DynamicProxy.dll
Copied DotNetOpenAuth.dll
Copied EPiServer.Common.Cache.dll
Copied EPiServer.Common.ComponentArt.Web.UI.dll
Copied EPiServer.Common.Configuration.dll
Copied EPiServer.Common.Criteria.dll
Copied EPiServer.Common.Data.dll
Copied EPiServer.Common.EventCounter.dll
Copied EPiServer.Common.Framework.dll
Copied EPiServer.Common.Framework.Exceptions.dll
Copied EPiServer.Common.Framework.Impl.dll
Copied EPiServer.Common.Security.dll
Copied EPiServer.Common.Web.Authorization.dll
Copied EPiServer.Common.Web.dll
Copied Iesi.Collections.dll
Copied log4net.dll
Copied Microsoft.Practices.EnterpriseLibrary.Common.dll
Copied Microsoft.Practices.EnterpriseLibrary.Data.dll
Copied Microsoft.Practices.ObjectBuilder.dll
Copied NHibernate.dll
Copied EPiServer.Common.Web.Authorization.Multiplexing.dll
Adding/Updating assembly redirect for EPiServer.Common.Cache
Adding/Updating assembly redirect for EPiServer.Common.ComponentArt.Web.UI
Adding/Updating assembly redirect for EPiServer.Common.Configuration
Adding/Updating assembly redirect for EPiServer.Common.Criteria
Adding/Updating assembly redirect for EPiServer.Common.Data
Adding/Updating assembly redirect for EPiServer.Common.EventCounter
Adding/Updating assembly redirect for EPiServer.Common.Framework
Adding/Updating assembly redirect for EPiServer.Common.Framework.Exceptions
Adding/Updating assembly redirect for EPiServer.Common.Framework.Impl
Adding/Updating assembly redirect for EPiServer.Common.Gadgets
Adding/Updating assembly redirect for EPiServer.Common.Security
Adding/Updating assembly redirect for EPiServer.Common.Web.Authorization
Adding/Updating assembly redirect for EPiServer.Common.Web.Authorization.Multiplexing
Copied EPiServer.Common.Gadgets.dll
Finish installing Common Framework
====Create Commerce Manager site
Entering commit phase
Committed
====Finish creating Commerce Manager IIS site
Unzip installer C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\
EPiServer Commerce 1.1.2.62\MediachaseECF\Mediachase.ECF.SDK.5.2.zip to C:\ECF1
499142707
Removing Alerts module from Commerce Manager
Removed Alerts.xml
Removed AlertsModule.ascx
Finish unzipping Commerce Manager installer.
Run installer silently
====Run C:\ECF1499142707\setup.exe
exit code of running setup.exe = 0
===Finish installing Commerce Manager site.
Copied CatalogCSVImportTab.ascx
Copied CatalogImportTab.ascx
Copied DialogPage.aspx
Copied PopupPage.aspx
Copied MetaDataImportTab.ascx
Copied MetaClassesControl.ascx
Copied MetaDataExport.ascx
Copied MetaFieldEditControl.ascx
Copied HelpModule.ascx
Copied Home.aspx
Copied LeftMenu.xml
Copied Authenticate.aspx
Copied GenerateToken.aspx
Copied DialogMasterPage.master
Copied ExtGrid.master
Copied FormDocumentDesigner.ascx
Copied MetaClassView.ascx
Copied RelationEdit.ascx
Copied RelationNNEdit.ascx
Copied ext-all2.css
Copied ibn.css
Copied Theme.CSS
Copied windows.css
Copied DialogTemplateLayout.ascx
Copied DialogTemplateNextNew.ascx
Copied EntityList.ascx
Copied EntitySelect.ascx
Copied EntityViewWithButtons.ascx
Copied ProfileEdit.ascx
Copied PickList-List.xml
Copied OrderCreate.ascx
Copied OrderCreateReturn.ascx
Copied PaymentMethodSelectControl.ascx
Copied TaxImportTab.ascx
Copied OrderSearch.ascx
Copied TopMenu.xml
Copied jquery.min.js
Copied Shell-ext.css
Copied Shell-ext.js
Copied UpTemplate.ascx
Copied ContentFrame.aspx
Copied default.aspx
Copied Licensing.aspx
Copied Login.aspx
Copied ManagementClient2.js
Copied grid.css
Copied grid_ie8.css
Copied GridStyle.css
Copied EPiServer.Business.Commerce.dll
Copied EPiServer.Licensing.dll
Copied Relations-List.xml
Copied EditProductRelationTab.ascx
Copied ProductRelations.resx
Copied EPiServer.Business.Commerce.ExtensionTabs.dll
Copying Commerce Core files...
Copied CommerceSettingsPlugIn.aspx
Copied CommerceManager.aspx
Copied AjaxControlToolkit.dll
Copied Common.Logging.dll
Copied Common.Logging.EntLib.dll
Copied Common.Logging.Log4Net.dll
Copied Common.Logging.NLog.dll
Copied ComponentArt.Charting.WebChart.dll
Copied ComponentArt.Web.UI.dll
Copied CuteEditor.dll
Copied CuteEditor.ImageEditor.dll
Copied ElektroPost.Licensing.dll
Copied EPiServer.Business.Commerce.UI.dll
Copied EPiServerCommonFramework.msm
Copied FredCK.FCKeditorV2.dll
Copied FreeTextBox.dll
Copied HttpWebAdapters.dll
Copied ICSharpCode.SharpZipLib.dll
Copied LitS3.dll
Copied Lucene.Net.dll
Copied Mediachase.BusinessFoundation.Data.dll
Copied Mediachase.BusinessFoundation.dll
Copied Mediachase.Commerce.dll
Copied Mediachase.Commerce.Marketing.Validators.dll
Copied Mediachase.Commerce.Plugins.Payment.dll
Copied Mediachase.Commerce.Plugins.Shipping.dll
Copied Mediachase.Commerce.Website.dll
Copied Mediachase.Commerce.Workflow.Activities.dll
Copied Mediachase.Commerce.Workflow.dll
Copied Mediachase.ConsoleManager.dll
Copied Mediachase.DataProvider.dll
Copied Mediachase.FCKeditorWrapper.dll
Copied Mediachase.FileUploader.dll
Copied Mediachase.Library.AmazonProviders.dll
Copied Mediachase.Licensing.dll
Copied Mediachase.MetaDataPlus.dll
Copied Mediachase.Search.dll
Copied Mediachase.Search.Extensions.dll
Copied Mediachase.Search.LuceneSearchProvider.dll
Copied Mediachase.SqlDataProvider.dll
Copied Mediachase.WebConsoleLib.dll
Copied Microsoft.Practices.ServiceLocation.dll
Copied Microsoft.ReportViewer.Common.dll
Copied Microsoft.ReportViewer.ProcessingObjectModel.dll
Copied Microsoft.ReportViewer.WebForms.dll
Copied Microsoft.Web.Administration.dll
Copied Moq.dll
Copied Moxiecode.TinyMCE.dll
Copied NetSpell.SpellChecker.dll
Copied nsoftware.IBizPay.dll
Copied RadEditor.Net2.dll
Copied Refresh.Web.FreeTextBox.dll
Copied RssToolkit.dll
Copied SpellChecker.Net.dll
Copied Validators.dll
Copied CatalogNodeBrowser.css
Copied CatalogNodeBrowser.js
Copied CmoGadget.js
Copied dashboard.css
Copied CustomerProperties.js
Copied OrdersFrequency.js
Copied ProductInCartOrWishList.js
Copied RecentOrders.js
Copied RecentSpent.js
Copied main.js
Copied OrderGadget.css
Copied OrderGadget.js
Copied Styles.css
Copied ProductPicker.css
Copied SettingsPlugin.css
Copied Mediachase.Search.Filters.xsd
Copied Mediachase.Search.Objects.xsd
Copied PerfDataSet.xsc
Copied PerfDataSet.xsd
Copied PerfDataSet.xss
Copied CatalogNodeBrowser.aspx
Copied DynamicContentPreview.aspx
Copied TagCloudActionWindow.ascx
Copied ProductPickerSettings.ascx
Copied editor_plugin.js
Copied editor_plugin_src.js
Copied ProductLinkProperties.aspx
Copied ProductPicker.aspx
Copied SelectProductControl.ascx
Copied CatalogPageProvider.aspx
Copied EPiServer.Business.Commerce.Gadget_DA.xml
Copied EPiServer.Business.Commerce.Gadget_EN.xml
Copied EPiServer.Business.Commerce.Gadget_FI.xml
Copied EPiServer.Business.Commerce.Gadget_NL.xml
Copied EPiServer.Business.Commerce.Gadget_NO.xml
Copied EPiServer.Business.Commerce.Gadget_SV.xml
Copied EPiServer.Business.Commerce.UI_DA.xml
Copied EPiServer.Business.Commerce.UI_EN.xml
Copied EPiServer.Business.Commerce.UI_ENUS.xml
Copied EPiServer.Business.Commerce.UI_FI.xml
Copied EPiServer.Business.Commerce.UI_NL.xml
Copied EPiServer.Business.Commerce.UI_NO.xml
Copied EPiServer.Business.Commerce.UI_SV.xml
Copied newtext_EPiServer.Business.Commerce.UI.xml
Copied newtext_EPiServer.Business.Commerce.UI_SENT.xml
Copied CommerceAdminUI.Master
Copied CommerceSettings.Master
Copied CommerceShellSettings.Master
Copied CommerceSite.Master
Copied EventService.svc
Copied ProductComment.svc
Copied ProductRating.svc
Copied Home.aspx
Copied LeftMenu.xml
Copied ext-all2.css
Copied ibn.css
Copied Theme.CSS
Copied windows.css
Copied TopMenu.xml
Copied Shell-ext.js
Copied default.aspx
Copied Login.aspx
Copied grid.css
Copied grid_ie8.css
Copied AssetStrings.da.resx
Copied AssetStrings.fi.resx
Copied AssetStrings.nl.resx
Copied AssetStrings.no.resx
Copied AssetStrings.sv.resx
Copied CatalogStrings.da.resx
Copied CatalogStrings.fi.resx
Copied CatalogStrings.nl.resx
Copied CatalogStrings.no.resx
Copied CatalogStrings.sv.resx
Copied ContentStrings.da.resx
Copied ContentStrings.fi.resx
Copied ContentStrings.nl.resx
Copied ContentStrings.no.resx
Copied ContentStrings.sv.resx
Copied CoreStrings.da.resx
Copied CoreStrings.fi.resx
Copied CoreStrings.nl.resx
Copied CoreStrings.no.resx
Copied CoreStrings.sv.resx
Copied Customer.da.resx
Copied Customer.fi.resx
Copied Customer.nl.resx
Copied Customer.no.resx
Copied Customer.sv.resx
Copied ProfileStrings.da.resx
Copied ProfileStrings.fi.resx
Copied ProfileStrings.nl.resx
Copied ProfileStrings.no.resx
Copied ProfileStrings.sv.resx
Copied DashboardStrings.da.resx
Copied DashboardStrings.fi.resx
Copied DashboardStrings.nl.resx
Copied DashboardStrings.no.resx
Copied DashboardStrings.sv.resx
Copied Common.da.resx
Copied Common.fi.resx
Copied Common.nl.resx
Copied Common.no.resx
Copied Common.sv.resx
Copied Global.da.resx
Copied Global.fi.resx
Copied Global.nl.resx
Copied Global.no.resx
Copied Global.sv.resx
Copied GlobalFieldManageControls.da.resx
Copied GlobalFieldManageControls.fi.resx
Copied GlobalFieldManageControls.nl.resx
Copied GlobalFieldManageControls.no.resx
Copied GlobalFieldManageControls.sv.resx
Copied GlobalFilterControls.da.resx
Copied GlobalFilterControls.fi.resx
Copied GlobalFilterControls.nl.resx
Copied GlobalFilterControls.no.resx
Copied GlobalFilterControls.sv.resx
Copied GlobalMetaInfo.da.resx
Copied GlobalMetaInfo.fi.resx
Copied GlobalMetaInfo.nl.resx
Copied GlobalMetaInfo.no.resx
Copied GlobalMetaInfo.sv.resx
Copied IbnFramework.Filter.da.resx
Copied IbnFramework.Filter.fi.resx
Copied IbnFramework.Filter.nl.resx
Copied IbnFramework.Filter.no.resx
Copied IbnFramework.Filter.sv.resx
Copied IbnFramework.GlobalMetaInfo.da.resx
Copied IbnFramework.GlobalMetaInfo.fi.resx
Copied IbnFramework.GlobalMetaInfo.nl.resx
Copied IbnFramework.GlobalMetaInfo.no.resx
Copied IbnFramework.GlobalMetaInfo.sv.resx
Copied MetaForm.da.resx
Copied MetaForm.fi.resx
Copied MetaForm.nl.resx
Copied MetaForm.no.resx
Copied MetaForm.sv.resx
Copied MarketingStrings.da.resx
Copied MarketingStrings.fi.resx
Copied MarketingStrings.nl.resx
Copied MarketingStrings.no.resx
Copied MarketingStrings.sv.resx
Copied MetaDataBaseStrings.da.resx
Copied MetaDataBaseStrings.fi.resx
Copied MetaDataBaseStrings.nl.resx
Copied MetaDataBaseStrings.no.resx
Copied MetaDataBaseStrings.sv.resx
Copied OrderStrings.da.resx
Copied OrderStrings.fi.resx
Copied OrderStrings.nl.resx
Copied OrderStrings.no.resx
Copied OrderStrings.sv.resx
Copied ReportingStrings.da.resx
Copied ReportingStrings.fi.resx
Copied ReportingStrings.nl.resx
Copied ReportingStrings.no.resx
Copied ReportingStrings.sv.resx
Copied ShellStrings.da.resx
Copied ShellStrings.fi.resx
Copied ShellStrings.nl.resx
Copied ShellStrings.no.resx
Copied ShellStrings.sv.resx
Copied Admin.da.resx
Copied Admin.fi.resx
Copied Admin.nl.resx
Copied Admin.no.resx
Copied Admin.sv.resx
Copied AppConfigCommon.da.resx
Copied AppConfigCommon.fi.resx
Copied AppConfigCommon.nl.resx
Copied AppConfigCommon.no.resx
Copied AppConfigCommon.sv.resx
Copied CommerceManager.da.resx
Copied CommerceManager.fi.resx
Copied CommerceManager.nl.resx
Copied CommerceManager.no.resx
Copied CommerceManager.sv.resx
Copied ConsoleResources.da.resx
Copied ConsoleResources.fi.resx
Copied ConsoleResources.nl.resx
Copied ConsoleResources.no.resx
Copied ConsoleResources.sv.resx
Copied Forum.da.resx
Copied Forum.fi.resx
Copied Forum.nl.resx
Copied Forum.no.resx
Copied Forum.sv.resx
Copied GlobalResources.da.resx
Copied GlobalResources.fi.resx
Copied GlobalResources.nl.resx
Copied GlobalResources.no.resx
Copied GlobalResources.sv.resx
Copied MetaView.da.resx
Copied MetaView.fi.resx
Copied MetaView.nl.resx
Copied MetaView.no.resx
Copied MetaView.sv.resx
Copied News.da.resx
Copied News.fi.resx
Copied News.nl.resx
Copied News.no.resx
Copied News.sv.resx
Copied SharedStrings.da.resx
Copied SharedStrings.fi.resx
Copied SharedStrings.nl.resx
Copied SharedStrings.no.resx
Copied SharedStrings.sv.resx
Copied create-dbo.sql
Copied setup.bat
Copied baf.config.xmlupdate
Copied Bundle-Edit.xml.xmlupdate
Copied Commerce.episerverdata
Copied commerce_enableENUSLanguage.sql
Copied DynamicPackage-Edit.xml.xmlupdate
Copied ecf.app.config.xmlupdate
Copied ecf.appSettings.config.upgrade.xmlupdate
Copied ecf.web.config.upgrade.xmlupdate
Copied ecf.web.config.xmlupdate
Copied ecf_CreateCMSRoles.sql
Copied ecf_createDefaultAssociationType.sql
Copied ecf_products_ProductsQuery.sql
Copied ecf_reporting_ProductsBestSellers.sql
Copied ecf_upgrade.sql
Copied Mediachase.EpiServer.lic
Copied Mediachase.License.config.xmlupdate
Copied Mediachase.Search.config.upgrade.xmlupdate
Copied Mediachase.Search.config.xmlupdate
Copied Package-Edit.xml.xmlupdate
Copied pageprovider.config.xmlupdate
Copied Product-Edit.xml.xmlupdate
Copied Variation-Edit.xml.xmlupdate
Copied web.config.upgrade.xmlupdate
Copied web.config.xmlupdate
Copied Add.ascx
Copied Detail.ascx
Copied Edit.ascx
Copied Index.ascx
Copied Edit.ascx
Copied Configure.ascx
Copied Index.ascx
Copied PerformanceReport.rdlc
Copied ShowReport.aspx
Copied Edit.ascx
Copied Index.ascx
Copied Edit.ascx
Copied Edit.ascx
Copied Edit.ascx
Copying gadget files...
Copied Add.ascx
Copied Detail.ascx
Copied Edit.ascx
Copied Index.ascx
Copied Index.ascx
Copied Index.ascx
Copied baf.config
Copied baf.data.manager.config
Copied baf.data.metaobject.config
Copied baf.library.folders.config
Copied ecf.asset.config
Copied ecf.catalog.config
Copied ecf.cms.config
Copied ecf.customer.config
Copied ecf.customization.config
Copied ecf.marketing.config
Copied ecf.order.config
Copied ecf.security.config
Copied ecf.ssl.config
Copied ecf.workflow.config
Copied Mediachase.Search.Filters.config
Copied module.config
#text
EcfSqlConnection
Data Source=BIZPC567\SQL2008EXPRESS;Initial Catalog=TranslinkCommMgr;Integra...
name
/configuration/connectionStrings
Copied News.da.resx
Copied News.fi.resx
Copied News.nl.resx
Copied News.no.resx
Copied News.sv.resx
Import Page provider Entry page
An error has occured and the transaction will be rolled back
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\SqlScripts to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\SqlScripts
Could not find a part of the path 'create-dbo.sql'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\CommerceManagerResource\App_GlobalResources\Shell to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\CommerceManagerResource\App_GlobalResources\Shell
Could not find a part of the path 'ShellStrings.da.resx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\CommerceManagerResource\App_GlobalResources\Reporting to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\CommerceManagerResource\App_GlobalResources\Reporting
Could not find a part of the path 'ReportingStrings.da.resx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\CommerceManagerResource\App_GlobalResources\Order to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\CommerceManagerResource\App_GlobalResources\Order
Could not find a part of the path 'OrderStrings.da.resx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\CommerceManagerResource\App_GlobalResources\MetaDataBase to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\CommerceManagerResource\App_GlobalResources\MetaDataBase
Could not find a part of the path 'MetaDataBaseStrings.da.resx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\CommerceManagerResource\App_GlobalResources\Marketing to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\CommerceManagerResource\App_GlobalResources\Marketing
Could not find a part of the path 'MarketingStrings.da.resx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\CommerceManagerResource\App_GlobalResources\IbnFramework to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\CommerceManagerResource\App_GlobalResources\IbnFramework
Could not find a part of the path 'Common.da.resx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\CommerceManagerResource\App_GlobalResources\Dashboard to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\CommerceManagerResource\App_GlobalResources\Dashboard
Could not find a part of the path 'DashboardStrings.da.resx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\CommerceManagerResource\App_GlobalResources\Customer to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\CommerceManagerResource\App_GlobalResources\Customer
Could not find a part of the path 'Customer.da.resx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\CommerceManagerResource\App_GlobalResources\Core to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\CommerceManagerResource\App_GlobalResources\Core
Could not find a part of the path 'CoreStrings.da.resx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\CommerceManagerResource\App_GlobalResources\Content to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\CommerceManagerResource\App_GlobalResources\Content
Could not find a part of the path 'ContentStrings.da.resx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\CommerceManagerResource\App_GlobalResources\Catalog to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\CommerceManagerResource\App_GlobalResources\Catalog
Could not find a part of the path 'CatalogStrings.da.resx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\CommerceManagerResource\App_GlobalResources\Asset to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\CommerceManagerResource\App_GlobalResources\Asset
Could not find a part of the path 'AssetStrings.da.resx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\CommerceManagerResource\App_GlobalResources to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\CommerceManagerResource\App_GlobalResources
Could not find a part of the path 'Admin.da.resx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Shell\Styles\IE8 to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Shell\Styles\IE8
Could not find a part of the path 'grid_ie8.css'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Shell\Styles\css to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Shell\Styles\css
Could not find a part of the path 'grid.css'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Shell\Styles to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Shell\Styles
Could not find a part of the path 'GridStyle.css'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Shell\Scripts to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Shell\Scripts
Could not find a part of the path 'ManagementClient2.js'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Shell\Pages to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Shell\Pages
Could not find a part of the path 'ContentFrame.aspx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Shell\Modules to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Shell\Modules
Could not find a part of the path 'UpTemplate.ascx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Shell\EPi\Shell\Resources to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Shell\EPi\Shell\Resources
Could not find a part of the path 'Gradients.png'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Shell\EPi\Shell\Light\Resources to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Shell\EPi\Shell\Light\Resources
Could not find a part of the path 'Cancel.gif'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Shell\EPi\Shell\Light to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Shell\EPi\Shell\Light
Could not find a part of the path 'jquery.min.js'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Shell\Config\View to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Shell\Config\View
Could not find a part of the path 'TopMenu.xml'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Order\Tabs to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Order\Tabs
Could not find a part of the path 'TaxImportTab.ascx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Order\Modules to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Order\Modules
Could not find a part of the path 'OrderCreate.ascx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Order\Config\View\Grids to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Order\Config\View\Grids
Could not find a part of the path 'PickList-List.xml'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Order to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Order
Could not find a part of the path 'OrderSearch.ascx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\MetaUIEntity\Modules to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\MetaUIEntity\Modules
Could not find a part of the path 'EntityList.ascx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\MetaUIEntity\Layout to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\MetaUIEntity\Layout
Could not find a part of the path 'DialogTemplateLayout.ascx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\MetaDataBase\styles to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\MetaDataBase\styles
Could not find a part of the path 'ext-all2.css'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\MetaDataBase\Modules\ManageControls to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\MetaDataBase\Modules\ManageControls
Could not find a part of the path 'MetaClassView.ascx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\MetaDataBase\MetaUI\MetaForm to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\MetaDataBase\MetaUI\MetaForm
Could not find a part of the path 'FormDocumentDesigner.ascx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\MetaDataBase\MasterPages to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\MetaDataBase\MasterPages
Could not find a part of the path 'DialogMasterPage.master'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\MetaDataBase\images to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\MetaDataBase\images
Could not find a part of the path 'leftCorner.GIF'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\EPiServerSSO to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\EPiServerSSO
Could not find a part of the path 'Authenticate.aspx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\EPiServerCMS\Config\View\Navigation to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\EPiServerCMS\Config\View\Navigation
Could not find a part of the path 'LeftMenu.xml'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Dashboard\Modules to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Dashboard\Modules
Could not find a part of the path 'HelpModule.ascx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Dashboard to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Dashboard
Could not find a part of the path 'Home.aspx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Core\MetaData\Admin\Tabs to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Core\MetaData\Admin\Tabs
Could not find a part of the path 'MetaDataImportTab.ascx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Core\MetaData\Admin to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Core\MetaData\Admin
Could not find a part of the path 'MetaClassesControl.ascx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Core\images to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Core\images
Could not find a part of the path 'btn_close.gif'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Core\Controls to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Core\Controls
Could not find a part of the path 'DialogPage.aspx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Catalog\Tabs to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Catalog\Tabs
Could not find a part of the path 'CatalogCSVImportTab.ascx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Apps\Asset\Images\FileType to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup\Apps\Asset\Images\FileType
Could not find a part of the path 'folder.gif'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\Setup
Could not find a part of the path 'baf.config.xmlupdate'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\ExtensionTabs\Tabs to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\ExtensionTabs\Tabs
Could not find a part of the path 'EditProductRelationTab.ascx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\ExtensionTabs\Config\View to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\ExtensionTabs\Config\View
Could not find a part of the path 'Relations-List.xml'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\ExtensionTabs\bin to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\ExtensionTabs\bin
Could not find a part of the path 'EPiServer.Business.Commerce.ExtensionTabs.dll'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\ExtensionTabs\App_GlobalResources to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\ExtensionTabs\App_GlobalResources
Could not find a part of the path 'ProductRelations.resx'.
Failed to rollback copying of files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\App_Themes\Default\Images\Tools\dark to D:\Episerver\Biznet.Translink.Web\Biznet.Translink.Web.UI\App_Themes\Default\Images\Tools\dark
Could not find a part of the path 'commerce_manager.gif'.
Rolledback
===in trapping ex ===
An unhandled error has occured:
Cannot resolve dependencies for the following module(s)
EPiServer.Web.InitializationModule
When executing
At C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Com
merce 1.1.2.62\Install EPiServer Commerce.ps1:647 char:37
+     $importedPageId = Add-EPiServerData <<<<  $catalogPageProviderImportFile $se
lectedWebApplication.PhysicalPath $selectedWebApplication.ApplicationName
inTransaction = False
Copy-Item : Item with specified name D:\Episerver\Biznet.Translink.Web\Biznet.T
ranslink.Web.UI\Installer logs\Installer logs already exists.
merce 1.1.2.62\Install EPiServer Commerce.ps1:85 char:11
+     Copy-Item <<<<  $sourcePath $destinationPath -recurse
    + CategoryInfo          : ResourceExists: (D:\Episerver\Bi...\Installer log
s:String) [Copy-Item], IOException
    + FullyQualifiedErrorId : DirectoryExist,Microsoft.PowerShell.Commands.Copy
ItemCommand
Deleting Commerce Manager Website in IIS
At C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Install EPiServer Commerce.ps1:29 char:19
+         Remove-EPiWebApp <<<<  -SiteName $wizard.CommerceManagerSite.SiteName -ApplicationName $wizard.CommerceManagerSite.ApplicationName -TryRemoveAppPool
System.Management.Automation.PSInvalidOperationException: The WriteObject and WriteError methods cannot be called from outside the overrides of the BeginProcessing, ProcessRecord, and EndProcessing methods, and only from that same thread. Validate that the cmdlet makes these calls correctly, or please contact Microsoft Support Services.
   at System.Management.Automation.MshCommandRuntime.ThrowIfWriteNotPermitted(Boolean needsToWriteToPipeline)
   at System.Management.Automation.MshCommandRuntime.WriteHelper_ShouldWrite(ActionPreference preference, ContinueStatus lastContinueStatus)
   at System.Management.Automation.MshCommandRuntime.WriteVerbose(VerboseRecord record)
   at System.Management.Automation.MshCommandRuntime.WriteVerbose(String text)
   at System.Management.Automation.Cmdlet.WriteVerbose(String text)
   at EPiServer.Install.UI.CmdletProgressHelper.WriteVerbose(String message)
   at EPiServer.Install.UI.CmdletProgressHelper.Progress_Updated(Object sender, ProgressEventArgs e)
   at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
   at EPiServer.Install.InstallationManager.WriteProgress(ProgressType type, String message)
   at EPiServer.Install.InstallationManager.BeginBulkInstall(Boolean supportDistributedTransaction, Boolean startMSDTC)
   at EPiServer.Install.InstallationManager.Install(Installer installer)
   at EPiServer.Install.WebServer.WebAppInstallationManager.RemoveIIS7WebApp(String siteName, String applicationName, Boolean tryDeleteAppPool)
   at EPiServer.Install.WebServer.WebAppInstallationManager.RemoveWebApp(String siteName, String applicationName, Boolean tryDeleteAppPool)
   at EPiServer.Install.WebServer.Cmdlets.RemoveWebAppCmdlet.ProcessRecord()
   at System.Management.Automation.Cmdlet.DoProcessRecord()
   at System.Management.Automation.CommandProcessor.ProcessRecord()
#61114
Sep 07, 2012 11:15
Falling over when attempting "Import Page provider Entry page"
#61118
Sep 07, 2012 12:44
It is recommended that you install Commerce on an empty CMS site, as installing new sample templates (such as Enoteca) on an existing sample site can cause problems (as you've come across).
#61140
Sep 07, 2012 22:01
it might well be recommended to install commerce into a new clean CMS each & everytime but this isnt always possible in real world. The site is already existing and hence it needs commerece installed into it.
so its not possible to install episerver commerce into an existing episerver cms site?
#61145
Edited, Sep 09, 2012 12:36
Sorry for the confusion, but you should be able to install Commerce on an existing site (my last response was just the recommended approach if possible). Unfortunately, the error doesn't give enough detail to pinpoint the problem. Sometimes just re-running the Commerce installer a second time you don't get an error. If you encounter the error continuously, please refer to this blog post on how to setup the installer that will retain the logs that will help us troubleshoot the error: http://world.episerver.com/Blogs/Tobias-Nilsson/Dates/2012/1/Problems-installing-EPiServer-Commerce/
#61219
Sep 12, 2012 0:49
the attempted re-install after initial failure gives the same error again.
following on from that blog post. When it retains the logs, what logs am i looking for to find errors?
#61240
Edited, Sep 12, 2012 15:06
I have just been having the same problem. The error is occuring at the point:
- Import Page provider Entry page
- An error has occured and the transaction will be rolled back.
The rollback erros are just confusing matters.
I re-insallted the commerece module from the deployment center and un-selected "Install Catalog Page Provider". The install worked fine.
After looking at the commerce powershell script (C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Install EPiServer Commerce.ps1) the catalog page prodiver task seems to import some data and apply a web config transform (line 641 onwards)
# if user want to install PageProvider (tick with checkbox)
if ($features.enablePageProvider)
Set-EPiProgressStatus -status "Import Page provider Entry page"
echo "Import Page provider Entry page"
$catalogPageProviderImportFile = Join-Path $setupFolder 'Commerce.episerverdata'
$importedPageId = Add-EPiServerData $catalogPageProviderImportFile $selectedWebApplication.PhysicalPath $selectedWebApplication.ApplicationName
Set-EPiProgressStatus -status "Update web.config to include page provider entry"
echo "Update web.config to include page provider entry"
$pageProviderConfig = Join-Path $setupFolder 'pageprovider.config.xmlupdate'
Update-EPiXmlFile -TargetFilePath $targetWebConfigFile -ModificationFilePath $pageProviderConfig -Replaces "{entryPoint}=$importedPageId"
} # end if features.enablePageProvider
This is as far as i've got. Am now looking into why this part is failing.
Hope this helps.
Adam
#61302
Sep 14, 2012 16:14
.. so it was actually very easy to run this part manually (for me anyway!)
1. log into admin and perform a data import from "C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Commerce 1.1.2.62\Setup\Commerce.episerverdata"
This will import one page into the system. I dont think it matters where it is located.
2. Update the episerver.config file with
<pageProvider>
    <providers>
      <add name="CatalogPageProvider" type="EPiServer.Business.Commerce.Providers.CatalogPageProvider, EPiServer.Business.Commerce" capabilities="MultiLanguage" entryPoint="22" />
    </providers>
  </pageProvider>
The value of entryPoint will need to be id of the page that was imported from the commerce.episerverdata file.
#61303
Sep 14, 2012 16:24
Hi Adam - thanks for that!
Tried installing with the catalog page provider unchecked but now get a different error, so at least its some progress!
error:
Enable en-US language
You cannot call a method on a null-valued expression.
When executing
merce 1.1.2.62\Install EPiServer Commerce.ps1:697 char:32
+         if ($langElement.GetAttribute <<<< ("id") -eq "en")
inTransaction = True
and then from the script itself:-
#copy en language files and modify them to be en-US language files
$langFolder = Join-Path $selectedWebApplication.PhysicalPath "lang"
$langFiles = Get-ChildItem $langFolder -Include "*.xml" -Force -Recurse
foreach ($langFile in $langFiles)
    [xml]$xmlContent = Get-Content $langFile
    foreach ($langElement in $xmlContent.languages.language)
        # manipulate the language file with id is "en" only
        if ($langElement.GetAttribute("id") -eq "en")
            # get file name without extension
            $fileName = [System.IO.Path]::GetFileNameWithoutExtension($langFile)
            $extension = $langFile.Extension
            $newLangFile = Join-Path $langFolder "$fileName.ENUS.$extension"
            [System.IO.File]::Copy($langFile, $newLangFile, $true)
            Set-EPiXmlAttribute -TargetFilePath $newLangFile -ElementXPath "/languages/language[@id='en']" -AttributeName "id" -AttributeValue "en-us"
            break
#61335
Sep 17, 2012 12:39
When I started the installation, the only language I had enabled in my site was en-US.
If you havent already, maybe for the purposes of the installation you could enable it and then disable it after it completes.
#61342
Sep 17, 2012 15:07
it seems epicode.xpublish.xml within the lang folder was the issue with lang
spot the spelling mistake!
<?xml version="1.0" encoding="utf-8" ?>
<languagees>
  <language name="norsk"
            id="no">
    <xpublish>
      <intro>Publisèr vil krysspublisere denne siden til noder i listen under</intro>
      <msgafterpublish>Denne siden har nå blitt krysspublisert til følgende sider:</msgafterpublish>
      <save>Publisèr</save>
    </xpublish>
  </language>
  <language name="English"
            id="en">
    <xpublish>
      <intro>Save will cross publish current Page to nodes added in list below</intro>
      <msgafterpublish>Current page has now been cross published to the following places:</msgafterpublish>
      <save>Save</save>
    </xpublish>
  </language>
</languagees>
#61351
Sep 17, 2012 16:21
and the import worked without any hitches
Adam your help has been greatly appreciated on all this!
Cheers,
Craig
#61353
Sep 17, 2012 16:39
