Processing a PurcahseOrder with XSL
I'm trying to process a PurchaseOrder according to this example. The problem is that I want to list the ListItems under each Shipment and the examples given in this documentation doesn't show how the LineItemIds node looks when it has children. Therefor I don't know how to write my XSL to get it right since the XML can't be viewed in any way I see possible.
One strange thing is that on the OrderForm.Shipments.Shipment object i code behind the LineItems under each Shipment is called LineItemIndexes instead of LineItemIds and is of type string[]. The code I'm trying to use looks like this:
<xsl:template match="Shipment">
<xsl:for-each select="LineItemIds">
    <xsl:call-template name="LineItem">
        <xsl:with-param name="index" select="LineItemIds[0]">
        </xsl:with-param>
    </xsl:call-template>
</xsl:for-each>
Of course the LineItemIds[0] would be replaced with something from the for-each but what? And is the name LineItemIds correct or should it be LineItemIndexes. Tried both but nothing produce any output.
Removing the for-each and just calling it with the following code gives me the right node with index 3
    <xsl:with-param name="index" select="3">
    </xsl:with-param>
So I just have to replace the select with the right index from Shipment LineItemIndexes (or LineItemIds)
#58833
May 08, 2012 15:16
Turned out that the LineItemIds wasn't in the XML at all. Changed to do the output not based on XSL/XML but used a UserControl instead and fecthed directly from the purchaseOrder object.
#58972
May 14, 2012 17:07
