ProfileProvider question in regards to Commerce R2
In the enotaca sample site, the site uses the SqlServerProfileProvider, but it is configured with automaticSaveEnabled=true, which means that every single page view will result in a call to a stored procedure which will perform a number of selects and potientially an update to the database. This is bad for performance, so i was wondering if this setting is needed for Commerce to function properly or if i can disable it?
#63817
Nov 30, 2012 10:41
I think it could work fine if you set the automaticSaveEnabled to false. Or you can intercept this in the Global.asax:
void Profile_ProfileAutoSaving(object sender, ProfileAutoSaveEventArgs e)
{ e.ContinueWithProfileAutoSave=false;}
In ProfileModule ( EPiServer.Business.Commerce ), you could also see that it intercepts this event if the HttpContext.Items["CancelProfileAutoSave"] is true.
if ((e.Context.Items["CancelProfileAutoSave"] != null) && ((bool) e.Context.Items["CancelProfileAutoSave"]))
e.ContinueWithProfileAutoSave = false;
#63860
Dec 03, 2012 10:31
