Could not load file or assembly 'EPiServer.Business.Commerce.Sample
I am having problems installing EPiServer Commerce.
- I installed EPiServer CMS 6.0. It seems to be running.
- I installed EPiServer Commerce. It seems to be running as well, in a different website, not related to the CMS.
- Tried to install EPiServer Commerce Sample, but encountered the following error:
Error - Could not load file or assembly 'EPiServer.Business.Commerce.Sample, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
I wish to install EPiServer Commerce and develop for it. What should I do?
Rotem
#43625
Sep 20, 2010 18:16
Update:
I erased everything, uninstalled EpiServer Deployment Center and started all over again.
Now I have the CMS 6 installed together with the Commerce Manager at the same admin panel, which is working as well.
My only problem now is installing the sample commerce website, same error as mentioned in my first post.
-- Rotem
#43710
Sep 21, 2010 23:33
Hi Rotem,
I think you need to compile the Commerce Sample project, before you can continue. Have you tried that?
#43714
Sep 22, 2010 9:07
Thanks Tobias.
I tried to compile the project and received the following errors in several places:
Error 6 'Mediachase.Search.SearchManager' does not contain a definition for 'GetIndexSearcher' and no extension method 'GetIndexSearcher' accepting a first argument of type 'Mediachase.Search.SearchManager' could be found (are you missing a using directive or an assembly reference?) C:\Program Files\EPiServer\CMS\6.0.530.0\Install\Modules\EPiServer Commerce Sample\Application\Templates\Commerce\Pages\ProductListing.aspx.cs 113 54 CommerceSample
As a side note, how come this is not documented? or is it? :)
Rotem
#44853
Oct 18, 2010 17:06
Check what version of the EPiServer.Business.Commerce.Sample you have in your bin-folder. If it's not 1.0.0.0, then you need to add a assembly redirect in your web.config and point to the new version. Also which version of Commerce do you have? 1.0 SP1?
Regarding the documentation, it have worked without a hitch before.
#44855
Oct 18, 2010 17:15
<p>Hi Rotem,</p> <p>I have blogged about the installation process here: <br /><a href="http://www.epinova.no/blog/arild-henrichsen/dates/2010/9/episerver-ecommerce-installation---redoux/">http://www.epinova.no/blog/arild-henrichsen/dates/2010/9/episerver-ecommerce-installation---redoux/</a></p> <p>You should not have to compile anything, the Sample pack should install smoothly.</p>
#44858
Edited, Oct 18, 2010 20:11
I am running into this same error as well when trying to install the sample.  "Error - Could not load file or assembly 'EPiServer.Business.Commerce.Sample, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified."
I am using "EPiServer CMS 6.0.530.0.zip" and "EPiServer Commerce 1.0 SP1.msi" to install episerver and the commerce part.
I followed the instructions on episerver's documentation as well as Arild Henrichsen's instructions on his blog.  Both result in this issue.
Anybody come up with a solution to this issue?
#47193
Jan 18, 2011 21:15
No solution, but I would suggest you re-donwload the msi package, save it and run it again to see if it fixes itself.
#47489
Jan 31, 2011 8:56
