In general with these errors
The cache data would also include the one in the Framework folders, e.g. run this in PowerShell
net stop w3svc
Remove-Item -Path "C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\*" -Force -Recurse
Remove-Item -Path "C:\Windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\root\*" -Force -Recurse
net start w3svc
If you want to clear the database check for duplicates first, the notification tables can be cleared without risk anyway.
It looks like a defragmention of the database did the trick. Have been running now for 4 days without these errors.
recently we have started to get a lot of "in use notification already exist" in our CMS11 episerver error logs. When this error occurs, our editors are unable to edit/save/publish content in episerver. We have been unable to find a solution since the error seems to be located within episerver (see error log)
We have noted that Optimizely has fixed a similar error in CMS12:
This problem makes it hard to work within episerver and we are wondering if there is a solution/fix/workaround for CMS11 ?
