CMS 11 non-DXP - problem copying blobs from one environment to another
We use CMS 11 hosted on Everweb.
We are trying to refresh one of our internal testing environments with content from another environment by simply taking a backup of the source environment database and restoring that to the target environment.
In addition to that, we copied the \App_Data\blobs folder in order to transfer all the images as well.
I am running the solution locally targeting the backup of the database and the blobs folder as set in Web.config:
<episerver.framework updateDatabaseSchema="false" createDatabaseSchema="true">
  <appData basePath="C:\dev\Atriaomat\dataa\App_Data" />
</episerver.framework>
I was expecting the blob data to be picked up and the images to show - but unfortunately they are not loading. Is there something else I should considering when moving content from one environment to another?
#334067
Dec 09, 2024 8:08
Does the application pool have access rights to that path? (C:\dev\Atriaomat\dataa\App_Data)
#334069
Dec 09, 2024 8:30
Eetu - Dec 09, 2024 8:34
Yes, I am simply running the solution via Visual Studio and targeting a folder on a drive on the same PC, there should be no restrictions,
Eric Herlitz - Dec 09, 2024 8:53
Do you have a web.development.config file with an alternative path perhaps? I'd still check the access rights.
