Custom importing script changes url to updated file
We are using CMS Core 11.20.11.
We have a job that imports files from a SharePoint Online document library. When a file is updated it gets the file again and overwrite the blob saved in Optimizely.
It have been working as it should. But lately something have changed. When it overwrites a file, the URL is updated with a "2" at the end. I can see that the file real name is still the same.
But links from outside of the CMS have stopped working. This used to work.
A couple of months ago we upgradet the nuget packages from CMS Core 11.14.1, is that the problem?
Best Regards
Niklas
#303873
Edited, Jun 21, 2023 7:07
Hi Niklas,
This sounds like a tricky one, I would suggest debugging the optimizely / your code code and see what is happening.
https://devblogs.microsoft.com/visualstudio/debugging-external-sources-with-visual-studio/
Once you know exactly what is happening and where, you can come up with a plan.
If the offending code is your code then unfortunately you will need to resolve (Would it take much work to delete and then re-upload? Might effect links though).
If the offending code is something MS / Optimizely reach out to their support teams and explain the problem you have found.
To me it doesn't sound like it is updating as it is adding a 2 to the end of the file and is more creating the file.
Paul
#303878
Jun 21, 2023 9:02
Hi Paul,
Thank you for your answer :)
I have been debugging our code, and I havent found anything that can add a "2" at the end. The functionality is automatic, people and scripts upload files to SharePoint Online. A Optimizely scheduled job checks if there is a new file or modified an existing file. Then downloads the file new/modified file.
We have had this functionality for about 3-4 years with no problem.
The problem seems to be specific for the URL in Optimizely CMS. When I check the file in the media side widget the filename is correct, but the URL has a "2" at the end.
I will check with Optimizely support team if there is something that have been changed. I checked changelogs but could not find anything specific.
I'll update this thread when we find out what the problem is.
Best Regards
Niklas
#303887
Jun 21, 2023 11:27
