Get a reference to each instance the block using the content repository (your code only gets the block defintion, not instances of the block) then use something like this:
ContentRepository.GetReferencesToContent(block.ContentLink, false)
Do what David wrote, but remember that you will not only get pages, but also other blocks, so you need to traverse until you find a page if that's what you want. If you use the function on a page you will get the places that have links to the page. Since you will get blocks in blocks you might end up with duplicates, so it's a good idea to also do a distinct on the list you get.
Hi MTM , you can use the content search capabilities provided by the CMS. Here's an example :
using EPiServer.Find;
using EPiServer.Find.Cms;
// Specify the block type you want to search for
var blockTypeName = "Your.Block.Namespace.YourBlockType";
// Perform a content search to find pages that reference the block type
var searchClient = SearchClient.Instance;
var searchResults = searchClient.Search<PageData>()
.Filter(x => x.BlockElements().MatchType(blockTypeName))
.GetContentResult();
// Iterate over the search results to access the pages
foreach (var hit in searchResults)
var page = hit.Document;
// Process the page as needed
// For example, you can access properties like page.Name, page.PageLink, etc.
in loop you can put the page in in list.
Using this code I can get all blocks available.
If I iterate this list, how do I get all pages that each block is used on?
